Roadstar steering wheel driver needed - Computers & Internet
  • Anonymous Dec 21, 2008
    usb adaptor not installed
  • Anonymous May 01, 2009
    yes same problem
    Novelist:
    Champion:
  • 233 Answers
If you don't have the install CD and Windows does not have the drivers, go to the manufactures web site and download from there.
Posted on Dec 25, 2008
How to replace steering wheel position sensor on a 2006 Cadillac DTS?
Manual Steering Column with JL4) or
Steering Wheel Position Sensor Replacement (Power Steering Column with JL4) ?
Preliminary Procedure Remove the intermediate steering shaft. Refer to Intermediate Steering Shaft Replacement .
Steering Angle Sensor Adapter
Procedure Disconnect any electrical connectors as needed.
Tip
If reusing, secure the old steering wheel position sensor before removing it for proper alignment upon reinstallation. Refer to Steering Wheel Position Sensor Centering .
Callout
Component Name
Notice: Secure the steering wheel utilizing a strap to prevent rotation. Locking of the steering column will prevent damage and a possible malfunction of the SIR system. The steering wheel must be secured in position before disconnecting the following components:
The steering column
The intermediate shaft
The steering gear
After disconnecting these components, do not move the front tires and wheels. Failure to follow these procedures may cause improper alignment of some components during installation and result in possible damage to the SIR coil.
Preliminary Procedure Remove the steering column. Refer to Steering Column Replacement .
Intermediate Steering Shaft Bolt
Procedure Remove the steering column boot seal in order to access the intermediate steering shaft bolt.
Intermediate Steering Shaft Nut
Notice: Refer to Fastener Notice in the Preface section.
Tighten
47 N?·m (35 lb ft)
Tip
If necessary, scribe location marks between the intermediate steering shaft and the steering column and the intermediate steering shaft and the steering gear to mark their alignment before removing.
If replacing the intermediate steering shaft, transfer any scribe marks from the old one to the new one.
Callout
Component Name
The steering column
The steering gear
Preliminary Procedures
  1. Remove the left side instrument panel insulator panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
  2. Remove the driver knee bolster. Refer to Driver Knee Bolster Replacement .
  3. Disconnect the intermediate steering shaft from the steering gear. Refer to Steering Gear Replacement .
Steering Column Nut (Qty: 4)
Notice: Refer to Title not found in the Preface section.
Tighten
25 N?·m (18 lb ft)
Steering Column
Procedure
  • Disconnect any electrical connectors as needed.
  • If equipped with AN3, disconnect the automatic transmission range selector cable. Refer to Automatic Transmission Range Selector Cable Replacement - Column .
  • Transfer any parts as needed.
  • Sep 12, 2015 | Cadillac Cars & Trucks
    Reset 2004 honda accord steering wheel controls?
    A thing called the "Clock Spring" in the steering wheel needs replacing. It has all the wires in that operate that stuff on the steering wheel and airbag. There may also be a sliding ground connection that could be bad or dirty.
    Feb 18, 2015 | 2004 Honda Accord
    How do I remove the steering wheel of my volvo xc60?
    You do not need a puller!
    DISCONNECT THE BATTERY AND WAIT 10 MINUTES!
    The top plastic cover on the steering column has to come off on the XC60. Release the steering adjuster and pull the column out and down. You will see a rubber seal. This has 10 clips that have to gently pried off. You can then remove the plastic upper cover from the front. (Nearest the steering wheel) It pulls up and out of the front clips and the bottom has lugs that slide out towards you if you are sat in drivers seat.
    Next the fun begins. You need a flat blade (s)crew driver with a 5.2mm blade end. (A 5mm works) You need to turn the steering wheel until you expose a rectangular slot in the back of it where the cover came from. Insert the (s)crew driver with the blade flat and level and touching the bottom of the hole. This will take a few attempts but you need to get the (s)crew driver under a clip and then turn the (s)crew driver 90 degrees to open the clip. You can then pull the airbag out slightly. (That is not easy either) once it is out about 10mm turn the steering 180 degrees and do the same with the other one. The air bag is now lose but the wires are very short. There is one position you can lay it where you can disconnect the two plugs which have the usual type of push in clips securing them.
    Put the airbag out of the way somewhere safe and facing up.
    You can now losen the 13mm bolt retaining the steering wheel but do not remove it yet. With the steering wheel straight, look in the cavity and at the bottom left is a small torx head (s)crew. If it won't unscrew, gently lever it out.
    Through the steering inner section at about the 11 "O" clock position you can see a slip ring. There is a small hole where the (s)crew goes into and locks into a recess to stop it moving. When it is locked you can remove the main steering wheel bolt taking car not to turn the steering wheel. If you have steering controls there will another plug to undo and you can then remove the steering wheel. There are two pins that go into the rear of the steering wheel so when you put it back together make sure they go properly and then reverse the above procedure. Do not forget to remove the little (s)crew a put it back where it cam from. The main bolt should be torques to 45nm.
    Mar 19, 2013 | 2010 Volvo XC60
    I have a tevion steering wheel, But i need a driver for it (On vista)
    This is for car and truck problems. Not computer issues for your game. Won't get help here. Try the marker of the steering wheel.
    Feb 07, 2018 | Cars & Trucks
    Steering wheel adjustment , the steering whell is 90degrees off but the car does not pull eather direction. car was stolen no damage just steering whell truned
    jack front of car up then turn steering wheel full lock to full lock and count the number of turns from either side then divide by 2 so you have the straight ahead position then remove the steering wheel and replace in the straight ahead position ,iam saying this because the vehicle may have been re tracked and only one track rod end adjusted so you have say 2 turns to the left and 2 and half to the right if you follow me .or remove the steering wheel then just hold it on and slowly drive forewards and lift wheel and refit to the correct position
    Feb 10, 2011 | 1999 Mercury Grand Marquis
    I need to replace the multi-function wiper switch on a 2003 Chev express van, what type of screw driver is needed to remove the steering column housing that contains the switch?
    the switch is underneath the steering wheel. the steering wheel needs to be pulled to replace the switch. the airbag is in the steering wheel, and a trained tech with a puller is needed to pull that wheel off without screwing up the airbag.
    Oct 30, 2010 | 2003 Chevrolet Express
    Need to remove the steering wheel so i can replace the turn signal/ dimmer switch. How do you remove the air bag so you can remove the steering wheel?
    Disconnect the battery negative/earth/.Wait for at list 10 minutes to deactivate SRS airbags.Then remove the drivers airbag useing 5 mm allan key behing the steering wheel.There is two holes.Disconnect carefully the airbag.24mm socket to unscrew the steering wheel.Pull out the steering wheel.Disconnect the plugs of the switches.There is 3 screws/flat screwdriver/ Thats all
    Jun 20, 2010 | 2002 Volkswagen Jetta TDI
    I bought a repoed 1700 roadstar and i am tring to remove the drivers seat i have tried everthing any tips the key has wheel lock and seat lock ? I have also tried that no luck. help.
    Put the key in the ignition. To lock the steering push the key down and turn the key. To unlock the seat, DON'T push the key down. Instead, just turn the key counter clockwise.
    FYI > Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
    Top rating for this answer? Thanks!
    Jun 10, 2009 | 2006 Yamaha Road Star
    Computers & Internet Logo
    1,242 people viewed this question
    Alun Cox
    David Payne
    David Payne
