Washing machine that no longer can spin dry laundry
Since two weeks ago, my washing machine has not been able to spin dry the load of laundry. If I kept repeating the spin process, the machine started generating some burning smell. Please advise on whether I should call in someone for repair or to buy a new washing machine.
  • sinkiew Dec 15, 2008
    Thanks for trying to help. The model of my washing machine is LG Fuzzy Logic 5.5kg T552A. When you mention new kit, what do you mean?
  • Washing Mach... Master
  • 8,220 Answers
The washer has a reversable motor. One way it washes and everything is sweet. the other direction the water pumps out and the brake gets released allows the tub to slowly start spinning and eventually spin out the water from the clothes. So what can go wrong? The thrust washer will not release the tub and let it spin. A new kit comes with everything you need to replace it.Since you never said what brand you have I am oly guessing of course by the symtoms you have given.Washing machine that no longer can spin dry laundr - eee0328.jpg
Posted on Dec 15, 2008
  • Dan Webster
    Dan Webster Dec 15, 2008
    I was refering to top loader models. Most of them work the same way. I do know most of the newer front loaders have a clean out on the pump. You have to get the lower front panel off to get to it. The cap twists off the pump housing and you can retrieve the junk out of the pump and maybe this will help.
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Purchased a Maytag Maxima washer two weeks ago--beginning to think it's ****. Have been trying to was a load of laundry for 2 1/2 hours now and can't get the washer to spin the load dry. Have tried...
I just bought the same washer and there is a problem with the steam sensing device. Check for code in time window. mine has a F08 and E01. Repairman coming in 2 days.
Feb 18, 2011 | Maytag Washing Machines
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The laundry is still wet after a normal wash cycle, because the machine doesn't get into the "high speed spin" (this has happened several times . . . have only had it 2 weeks). It has happened on full...
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
Jan 09, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I just did a load of laundry at my mom's beach house. Second load so far is fine, however, first load seemed to leek from underneath. All water/drainage connections were dry. We moved and cleaned area and...
If all connections were dry, the water may have overflowed the top of the tub during a spin /rinse cycle. That could happen if there was a lot of water (i.e. set for large load) and a small amount of clothes.
Jul 08, 2009 | Washing Machines
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 80 series heavy duty super capacity washer-new in 2002
HI colleen. thanks for the question. i know that you have been doing laundry for 30 yrs. i have been repairing for 45 years. they did not have daugs then. so the problem was not there. yes overloading is the cause . but if it wont go into the spin cycle . that could be the lid switch.
Oct 07, 2008 | Washing Machines
Washing machine won't drain
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
304 people viewed this question
Top Washing Machines Experts
