Question about Panasonic Lumix DMC-LZ8K Digital Camera
Batteries replaced but still says change them
Battery was running low on my camera, so I changed the AA batteries and also the lithium CR1220 battery. The screen still says change batteries and keeps shutting off as though there is no power. Have tried three different sets of batteries, all fully charged, which work in other devices.
I had the same problem; check carefully the yellow note from the camera box which says : use ONLY alkaline or rechargeable NI-Metal or oxyride batteries - DO NOT USE Ni-Cd nor lithium nor nickel nor manganese batteries. try that and pls let me know if it helped or if any other solution worked.
tx,
Peter
Posted on Aug 28, 2009
Difference between lithium battery and AA size battery for camera
"Lithium" refers to the chemical makeup of the battery. "AA" refers to the size of the battery. There are such things as lithium AA batteries.
If your camera takes AA batteries then lithiums will give you more shots than other types. They will also cost more.
Oct 06, 2014 | Nikon COOLPIX Cameras
Battery operated George Nelson Ball clock running slow
Probable cause is low battery voltage, maybe the battery was not fresh or was of too low quality. For such a nice clock, extra cost in getting an Energizer Ultimate Lithium or VARTA Professional Lithium cell is justified and the AA sized battery with 3000 mAh will work for many years. Otherwise, use Alkaline batteries and don't forget to check the expiration date always. Check http://www.batteryshowdown.com/results-lo.html to get some ideas on what to buy and what to expect.
Mar 05, 2014 | Home
It will say low battery or will not turn on
If your camera uses AA batteries, you should note the battery type your camera support, and many cameras only support Lithium AA batteries or Alkaline AA batteries, else there maybe note enough voltage, so the camera will note low power. If your camera uses special camera batteries, and maybe you should replace it for a new one.
Sep 05, 2011 | General Electric A950 Digital Camera
I have a Canon Power Shot A470. I have replaced the batteries many times, always with brand new ones, and it still keeps telling me to change the batteries. What is the problem with it? How do I fix it?
Yes, but what batteries have you been changing? If the AA's, those aren't the clock battery. Open the battery door, and notice the tiny door inside labeled "CR1220". Pry that door open with your fingernail, and take the enclosed CR1220 battery down to your local drugstore to purchase a replacement clock battery. Drugstores seem to be cheaper for this battery (~$3) than retail outlets like W-Mart (~$7).
Aug 22, 2011 | Canon PowerShot A470 Digital Camera
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
Every time I turn on my Canon A540 Powershot I get the black date/time screen. The date/time is all zero (the photo properties default to 1 Jan 1980) and I have to either enter the date/time or press...
Inside the battery compartment, right beside the AA batteries, there's a tiny little door labeled CR1220 (see this picture). Pry the door open with your fingernail, remove the little button battery located there, and take this battery down to your local drugstore to buy a replacement camera clock battery. Remember, it's a "CR1220" battery. It should cost only about $4.
Dec 29, 2010 | Canon PowerShot A540 Digital Camera
Canon A470 The date and time menu keeps popping up every time I switch on the camera despite setting the date and time.
There is another battery next the the AA battery under a little cover marked CR1220. That is the battery size. If that battery is dead, or has never been installed then every time you change the AA batteries the camera will forget the time and date. Try to get one from a specialty store that turns over its inventory quickly and you may find that you will only change this battery every 2 or 3 years.
Oct 31, 2009 | Canon PowerShot A470 Digital Camera
Canon A710IS Battery Drains Quickly
I have this issue as well, the camera seems to drain the batteries even when it is not on.
Oct 07, 2009 | Canon PowerShot A710 IS Digital Camera
Batttery icon shows low battery even though new batteries are ins
I am not sure if this will address your problem but it is worth trying.
Make sure the record/playback mode switch is not in an intermediate position. Push it firmly all the way up. Also ensure that the mode button is not between clickstops. Then try to operate the camera
If that does not help, try the following. Take all the batteries out, including the lithium battery which keeps the clock going. Also take the SD memory card out. Leave the camera sit overnight.
Obtain new batteries - conventional alkaline AAs and a lithium type CR1220.
Next day, clean all the contacts for the AA batteries with a cotton-bud and contact cleaner or isopropyl alcohol. Let dry. Then insert the new lithium battery. Next insert the new AAs and try to turn the camera on.
If it works, insert the SD card. If it does not work then there is probably an internal problem and it should be serviced.
Feb 06, 2009 | Canon PowerShot A720 IS Digital Camera
http://www.fixya.com/support/t1100571-lumix_dmc_lz5_replace_battery
try
Sep 05, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic Lumix DMC-LZ8K Digital Camera Logo
207 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
