Question about GE GSS25IFR Side by Side Refrigerator
Side by side ge not running
Our GE GSS25IFRI BB is not running at all. There no sounds of a compressor/motor running. The lights inside both fridge and freezer sides are working. I don't know what other information may be needed. Prior to this problem, for at least the past 1-1/2 years the ice dispenser quit working. when the lever was pushed to dispense ice the light would flash what seemed to be a code. It also cut out the freezer motor if it was running during the time you tried to dispense the ice. The water dispenser would only dispense water half the time. When it didn't work it would show some kind of a code as well. any help/direction would be appreciated.
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
t0pc4t
  • 132 Answers
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Posted on Aug 15, 2008
SOURCE: Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Posted on Nov 09, 2008
  • 37 Answers
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
Posted on Jan 03, 2009
My GE Adora Model dss25ksra refrigerator decided last night to stop working. It's a case of "the lights are on but nobody is home". The lights inside will come on when the doors open, but the compressor...
Yes it does sound like a motherboard issue=> WR55X10942 Main Control Board It is also good to replace the=> WR07X10057 Start Relay and WR62X0079 Run Capacitor and examine the condenser and evaporator fan motors to insure they are working properly if the motherboard has been replaced. I am here should you need me, Thanks John Tripp Appliance 911
Mar 27, 2014 | GE Adora DSS25KSTSS Stainless Steel Side...
GSS22KGPA side by side not cooling
Unplug the unit and pull the relay off the compressor and shake it to see if it rattles. Post back the results.
Nov 27, 2012 | GE Refrigerators
My GE fridge (gss25jemaww) stopped cooling. The light still goes on and off like normal, and the motor works, but the fridge and freezer do not cool anymore. Everything inside thawed.
This tell me the compressor is not running. I would like you to pull the fridge away from wall unplug and remove the cover over the compressor. Feel top of compressor and if too hot to hold hand there keep unplugged and let me know. There are some test I would like you or someone skilled with a test meter to do to eliminate the compressor start components and motherboard. Sea Breeze
Jan 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from GE Side by Side
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 07, 2009 | GE GSS22JF Side by Side Refrigerator
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
Ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Feb 21, 2009 | GE GSH25JFR Side by Side Refrigerator
GE ELANTRA MODEL ESS 25LGMB-BB
sounds like either your fan is bad or a wire may have burned off of it. Follow the wires forthe fan back to where they make the junction with the compressor wires. when ever the compressor runs your right that the fan needs to run. If you have a meter you could ohm out the fan and see if the motor windings are indeed bad. a reading of infinite would tell the tale.go out and spend 15 or 25 o us and get a new condenser fan motor after you remove your old one and make sure that the one that oyu get is the same. and replace it. Thanks for using FixYa and don't forget to rate this answer please. Happy New Year!!!!!!
Nov 05, 2008 | GE Profile PSS26NGS Side by Side...
Ge frigde
if it is the fan at the compressor not running, the system pressure will rise and cooling will ******, verify 120 volts to the fan motor if you have 120 volts ac replace the condenser fan motor
Apr 06, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE GSS25IFR Side by Side Refrigerator Logo
85 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
BOYNISMO
