Need wiring hook-up diagram for a philips dvd player to tv
And a satilite system
sandrew
  • 2961 Answers
SOURCE: philips dvd sarround soud set up with pc
The cables you use are what come from the speakers, but you will need to have a dedicated 2.1, 3.1, 5.1 or 7.1 surround sound card fitted, you cant split the sound channels from a normal stereo analogue sound card.
Posted on Oct 01, 2007
pishta68
  • 593 Answers
SOURCE: CONNECTING DVD/VCR TO CABLE BOX & TV ETC
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Posted on Feb 28, 2008
SOURCE: hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
Posted on Apr 13, 2008
dauphine
  • 207 Answers
SOURCE: yes i need all the codes for my cl034 universal philips 4 remote
You can get Phillips codes from here http://www.urc.philips.com/
Posted on Apr 29, 2008
IrishDruid
  • 2712 Answers
Symphonic - 0171
Apex - 0156
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 08, 2008
Set up of archos 605 wifi
can you provide the model numbers for the dvr station and hdd dvd player, please?
May 25, 2008 | Archos 605 WiFi Digital Media Player
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
We have a philips up-grader dvd player and get color distortion
I would try hooking something else up to your tv that is hdmi compatible. If your tv looks fine, then you know it would be the dvd player. If it's the dvd player, then I would suggest getting a different brand completely. I have had alot of bad experiences myself and other people as well when it comes to the philips brand
Apr 07, 2009 | Philips DVP3960
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
Philips home theater system
Recheck that you hooked it up exactly as stated in the quick start guide. If there is no sound when playing DVD, return it immediately or call Philips to get replacement. If you get sound when playing DVD, but from no other sources, then make sure that the end of the cord NOT plugged into the Philips says OUT or OUTPUT - many TV's do not have outputs.
May 24, 2008 | Philips Audio Players & Recorders
Hook up
Apr 12, 2008 | Philips Magnavox DVD/VCR Dual Player
How to hook up my dvd player to my cable box
Richard,
I would have to guess that you are hooking up a DVD recorder?
If you are then you take the video and audio cables out of the cable box and hook them in to the DVD R input plugs. The output wires go to the TV video/ audio in. Its just like hooking up a VCR.
Now if you are trying to hook the DVD player up to watch movies then you have to hook up the audio/video cables up from the DVD to the back of the TV into your Video 1/2 input. If you have the Component wires you hook them up the same way.
Now if your TV only has the one set of plugs (video/audio) then goto your local Audio/Video store and pick up the A/V cables that have the "Y" or "T" plug on one end.
I hope this helps you.
Mar 27, 2008 | Philips DVP5140 DVD Player
Televison & Video Logo
509 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
