Question about Kenmore 98702 Stacked Washer/Dryer
Washer will not stop filling up it overflows
It is a washer and dryer stack
  • Kenmore Master
  • 8,220 Answers
Very simple. No parts needed! Remove the pressure tube that connects from the water level switch down to th bottom of the tub. Blow out the trash that has accumulated in the bottom of the tub and re connect the tube to the water level switch. Drain the washer. Retry.washer will not stop filling up it overflows - a097efc.jpg
Posted on Dec 15, 2008
How do i get inside the washer
Posted on Dec 23, 2008
5 Suggested Answers
SOURCE: I have a Whirlpool stacked
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
  • 62 Answers
SOURCE: the washer/dryer combo dose not stop filling up with water
check the fill valve and the connections to it the problem probly lies inthere. the valve is located inside the machine where you water hooks up.
Posted on Jul 09, 2009
tunde007
  • 2382 Answers
SOURCE: Hi, I have a Frigidaire
Hi, if your washer is overfilling/overflows the tub, check these:
  • Water-inlet valve
  • Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Nov 07, 2010
jumptrout51
  • 3361 Answers
SOURCE: my maytag Lsg 7806AAE stacked
Your lid switch is bad.
Have the lid switch replaced.
Posted on Apr 10, 2011
Washer fills up with water and over flows
http://voices.yahoo.com/how-fix-overflowing-washing-machine-10363161.html
Apr 13, 2013 | Maytag LSE7806A Top Load Stacked...
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
I put too big a load in my washer, and then it overflowed. I drained it and unloaded it, but when i put in a new load, it overflowed again all over the house. What's going on? how do I fix it?
pull the front panel off you might find a small hose going from the control panel to the tub see if it came off if so just re-attach. If you have to turn the water off to stop the water then it is the fill valve and check the drain hose from the tub to the pump that it is still attached.
Nov 29, 2010 | Maytag LSE7806A Top Load Stacked...
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
Water does not shut off!!!
Check the timer in the back behind your knobs make sure it is working. That timer times how long for the water to run on all your settings and for everything else
Feb 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Hotpoint washer will not stop filing with water
It would appear you have a faulty water inlet valve.
Try turning the water off to the washer. if it stops filling, then that is your problem
Replace valve or valves as required.
Please leave feedback
Dec 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
193 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
