Question about Duke 59-E4Z Electric Single Oven
Duke Convection Oven won't heat past 250 degrees
My Duke convection oven has really slowed down it's ability to heat up properly. It doesn't seem to get hotter than 250-275 degrees. Any ideas?
Most likely a heating element.
Posted on Nov 08, 2009
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Why should the cooker burn that hot, when you can cook most things at a max 220Celsius
Sep 27, 2009 | Duke 59-E4Z Electric Single Oven
Heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Mar 01, 2009 | Ovens
Duke 59-E4Z Electric Single Oven Logo
731 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Duke Oven Expert? Answer questions, earn points and help others
