Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: Forgotten My Phone Lock Code
Ok, THIS WILL WORK! It worked on my W580i and it wasn't even supposed to. FIRST! Download (8.8MB) XS++ From HERE:http://forums.se-nse.net/index.php?showtopic=16338
SECOND! No install. It just runs.
Make sure you have ALL drivers for YOUR phone. That should be under the bettery. Under model... or something like that. HERE! http://www.nodevice.com/driver/company/Sony_Ericsson.html
Take your phone, turn it off. Start this program and click on connect. You'll have 30 seconds to plug your phone into your computer and HOLD C The entire time! (the delete button or 2). If connected, then click at the button: GDFS. There will be a phone lock reset to "0000". Click it. It will take no more than 45 seconds. I promise. Unplug your phone, and vuala! If your phone won't turn on, try pulling out the battery, putting it back and trying again. This program is also good for flashing phones, and putting flash menues on your phone. Also unlocking it and debranding it. GOOD LUCK!
Please Goto a Sony-Ericsson Service Centre They will Sove It ...............................
SOURCE: Phone Lock Code Forgotten (SE W200i)
press frm joystick write side once then press*then 2times joystik left side then *then again frm write sidepress once u will go into service menu then u can see ur passward. no need of smcard when u do this.reply me
SOURCE: Sony Ericsson W350i - replacement hinged keypad cover
While this may not be typically, I just talked with Sony Ericsson and they are sending me a new flip cover at no charge. I should receive it within 3-5 business days.
SOURCE: change phone lock code of ericsson w350i, old code
i have to lock my phone its sony erricsson w350i
