Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL
Problem for Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB...
I have a MAc OS , now i wanted to know How to Fix Bad Sectors on a Hard Disk?
By Cornish - usenet poster
Same Problem
Aug 05, 2008
-   this HD works with my Mac Book Pro, but does not work with my Mac Pro. I just don't know why it happens. Please help!-   dshrestha
Best Solution
posted on Apr 01, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If no good you can try using disc utility from the install disc [start while pressing 'c']
You can use a software like techtool which can help a little more sometimes, again as a last thing can boot from the techtool disc & try again.
If this doesn't do it then you can reformat [erase - same thing]the disc on the next tab on disc utility. Mac osx extended [journaled is usual for osx, but don't tick the os9 driver box [unless you need it.
If this doesn't do it the keep an eye on it as it's not 100% healthy
Solution #2
posted on Aug 08, 2005
Somewhat Helpful)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
1. If you're running Mac OS 9.2 or an earlier version, search your hard drive for a file called Disk First Aid. You can use this Apple-supplied utility to verify and repair disk errors.
2. If Disk First Aid says it can verify but not repair your disk because it's the startup disk, you should restart your Mac from the System CD-ROM disc that came with your computer. Hold down the C key during startup to force the Mac to start from the CD-ROM. Older Macs, pre-G3, need to press the Command- Opt-Shift-Delete combination.
3. If Disk First Aid fails to fix all the problems it detected the first time you run it, try running it a few more times
4. If you're running Mac OS X, you'll find that Disk First Aid has been made part of the Disk Utility program, which you'll find in the Utilities folder in the Applications folder. Click on the First Aid tab after launching Disk Utility.
Was this helpful?
Yes
No
Popular Solutions for Smartdisk - Peripherals - HARD
Questions and Unsolved Problems for Smartdisk - Peripherals - HARD
Do you recommend Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)?
Answer
Answer
I have Imac the apple I need windows 95 drivers and I don user. you  game to...
Answer
in my business contact manager/Outlook- in the history sectio it show all of my emails received, not... (More)
Answer
My flash drive will not work. When trying to access it, i am being asked to format the drive. I've... (More)
Answer
Hi, I have the same problem with a Smartdisk external HD that you reported in July '08, just... (More)
Answer
dear sir i have just bought one of your videosafe capture machines from pc world i installed the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
