Question about Ingersoll Rand 3/4" Dr. Super Duty Air Impact Wrench with 3" Anvil
I need to re-assemble a IR 3/4 impact. - Ingersoll Rand 3/4" Dr. Super Duty Air Impact Wrench with 3" Anvil
  • Rick Wymer
    Rick Wymer May 11, 2010
    Who took it apart? Is it the same Model as your Image? Model 261-3? I have a 261-3 Myself that's been Tweeked, in Fact Most of my Air Tools are IR.
    Do you have ALL the Parts?
    Problem Solver:
  • 6 Answers
Not easy y did u take it apart
Posted on Feb 21, 2009
Ingersollrand model 259 no power?
Loss of power in an impact wrench can have many causes (worn/broken impact mechanism, worn motor parts, dirty motor, etc.). It will need to be disassembled and serviced.
Aug 11, 2014 | Ingersoll Rand Ir 259 3/4" Dr Impact...
Replace reverse valve ir 2135
YOU NEED TO COMPLETELY DISASSEMBLE THE WHOLE TOOL.
START BY REMOVING THE 4 MOTOR HOUSING SCREWS, SLIDE THE HAMMER CASE, HAMMER ASSEMBLY AND MOTOR ASSEMBLY FROM THE MOTOR HOUSING.
THE REVERSE VALVE WILL BE VISIBLE NOTE THE ORIENTATION ON THE AIR OPENING IT LOOKS LIKE A HALF MOON, THE VALVE WITH EITHER BUTTON PRESSED IN SHOULD AT A 45 DEGREE ANGLE.
NEXT YOU WILL NEED TO REMOVE THE INLET BUSHING ASSEMBLY THAT IS HELD IN BY A CLIP THE IS VISIBLE THROUGH 2 SLOTS LOCATED ON THE LOWER SIDES OF THE GRIP, THEY NEED TO BE PRESSED IN TO SLIDE THE INLET BUSHING OUT THE BOTTOM OF THE TOOL. THERE IS A SPECIAL TOOL THAT SIMULTANEOUSLY PRESSES BOTH SIDES OF THE CLIP BUT CAN BE SUBSTITUTED WITH 2 SMALL FLAT HEAD SCREWDRIVERS.
ONCE THE INLET IS REMOVED, THE TRIGGER CAN SLIDE OUT THE FRONT OF THE TOOL
NEXT USE A SMALL FLAT HEAD SCREW DRIVER TO PRY THE REVERSE BUTTON OUT OF THE HOUSING, INSERT THE SCREW DRIVER INSIDE THE INNER EDGE TO PRY OUT,
ROTATE THE VALVE 45 DEGREES IN THE OTHER DIRECTION TO REMOVE THE SECOND BUTTON.
NEXT PUSH DOWN ON THE REVERSE VALVE IT WILL COME OUT THE BOTTOM.
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/IR%20Industrial%20Tools/Impact%20Tools/04584033_ed2.pdf
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
Ingerroll rand 2132g how do I oil my air impact wrench?
Most I.R. impacts require grease in the hammer mechanism (clutch) and oil in the air motor.
To lubricate the air motor simply add oil through the air inlet about 3 to 6 drops at every use.
To lubricate the hammer (clutch) mechanism you will need a grease gun with a needle, the grease fitting (item# 17) is located on the hammer case assembly (item# 15) 2 or 3 small squirts will sufficiently lube the hammer (clutch) mechanism.
With heavy use grease the tool once a month, with light use 2 to 3 times a year.
Follow this link for the parts list, also indicates the grease needed:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80164726_ed4.pdf
Aug 04, 2013 | Impact Husky® 1/2" Wrench
How do i install trigger kit in qtimax
Unfortunately IR does not have a maintenance manual for this model, but you can use the manual for a model 2131.
The air inlet assembly is slightly different on both models but the parts kit will fit both models, assembly and disassembly are the same.
Follow this link for a maintenance manual:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/45481785_ed1.pdf
Apr 03, 2013 | Ingersoll Rand Ingersollrand 2135timax 12"...
Ingersoll Rand 2100G air impact wrench turns when air is hooked up. I can stop it by hand and then use it with the trigger, and it works fine, but it continues to run even when I let the trigger go. What...
The I.R. 2100G shares parts with the 2135 series impact, the throttle valve seal on these models have a tendency to wear out or deteriorate casing the throttle valve to by pass air. On the model 2100G the parts in question is only sold as an assembly (item# 22).
But you can disassemble the inlet bushing and install an inlet parts kit p/n 2135-K303, it includes all the necessary parts.
I will provide to links for you to look at
2100G: http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45667599_ed2.pdf
2135Ti : http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
The I.R. parts list shows the inlet bushing in detail.
Oct 28, 2011 | Ingersoll Rand Air Tools & Compressors
Parts for older eletric impact
Ohio power tool stocks some of these IR items, your model interchanges with model 8049.
Mar 15, 2010 | Ingersoll Rand Ingersoll-Rand 1/2 in....
IR 2135TI repair manual
Go to: http://www.irtools.com/contact/?pro=&cat=&sbu=&formType=ussales
make a Request for schematic, they have always given me great assistance.
Dec 30, 2008 | Air Tools & Compressors
Ingersoll Rand 3/4" Dr. Super Duty Air Impact Wrench with 3" Anvil Logo
144 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
