Question about Uniden BC60XLT Handheld Scanner
I have a uniden bearcar scanner lost manual how do i enter codes model bc55xlt
  • 328 Answers
Http://www.fixya.com/support/p223851-uniden_bc60xlt_handheld_scanner/manual-13709
hope this helps...Good luck!
Posted on Dec 15, 2008
I have a hand held uniden scanner and need to know how to enter the codes in it. model bc72xlt
Welcome to fixya!
Func + Pgm - lets you program
the frequency.
If you need the manual you can get it on the link below.
http://www.uniden.com/pdf/BC72XLTom.pdf
Good Luck
Nov 09, 2010 | Uniden BC72XLT Handheld Scanner
How do i put a code in my uniden bearcat bc55xlt portable scanner
On the link below is the manual. On page 5 will tell you how to program.
http://ki4nsf.com/ham/BC-55xlt_Operating_guide.pdf
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know
Good Luck
Sep 03, 2010 | Uniden BC60XLT Handheld Scanner
How do you program a bearcat bc55xlrt scanner with a code?
There are no codes, only frequencies. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
To program your BC55XLT:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
You will want to lock out constant "broadcast" services such as NOAA or airport weather. Pressing Lockout will toggle the feature on and off.
Select a channel to program. Use the keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Jan 12, 2010 | Radio Communications
Programming a uniden scanner not sure how to program (put codes in ) Also finding the codes for chilliwack police and fire etc..?
Programming the 248 is fairly simple once you know the steps.
- Turn the scanner ON
- Press the MANUAL key to stop scanning
- Enter the channel number that you wish to program (01, 02, etc.)
- Press MANUAL
- Enter your frequency, including the decimal point (e.g. 156.055)
- Press E to confirm
- Press MANUAL to advance to the next channel
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, viksit:
Oct 02, 2009 | Uniden BC248CLT Base Scanner
Need to know how to put codes in
If your scanner is the BC350C (the section you posted in), here's a link to the owner's manual which will give you detailed programming information:
http://www.uniden.com/pdf/BC350Com.pdf
If you have a different model Bearcat scanner, try:
1. Push MANUAL to stop scanning and advance to the channel that you want to program.
2. Enter the desired frequency, including the decimal point (e.g., 156.015).
3. Press E or ENTER to set the frequency.
4. Repeat the process, starting with 1 above to select the channel.
NOTE: With some Bearcat scanners you may need to press the E or ENTER key before entering your frequency.
These are general steps that work on most recent Bearcat models. If they don't work on yours, try different variations. You can also check Uniden.com -- they may have an online manual that you can download and print.
Apr 25, 2009 | Uniden BC350C Base Scanner
Lost the codes for my scanner
hit manua enter number then Ebthat should put them in again
Jan 10, 2009 | Uniden BC244CLT Base Scanner
Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
Sep 26, 2008 | Uniden BC244CLT Base Scanner
Cannot re-enter codes
Uniden's website www.uniden.com has the manual for this radio.
Jul 13, 2008 | Uniden BC244CLT Base Scanner
Programin the codes in a bc60xlt bearcat scanner
I am not familar with that model scanner but all the uniden radios I have used have direct freq entry......Hit manual button, select what channel you wish to enter it in, hit manual again. Enter the freq desired, then hit enter. That should enter the freq in that channel space. Hit enter again to go to the next channel for programming. Hope this helps.
Mar 19, 2008 | Radio Communications
Programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Feb 11, 2008 | Uniden BC248CLT Base Scanner
Uniden BC60XLT Handheld Scanner Logo
122 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
