I need compatible software for my camera and my windows 7 computer
You don't need the Samsung software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: i need help...Samsung Digimax D53
Go to the following url and you will find the driver and manual: http://www.samsungcamera.com/customer/download/cus_down_main.asp?page=6&keyfield=&key=
SOURCE: software
driver of your D53 is not compatible with PC's running Vista. camera has plug and play connection with PC and when transferring files, camera could be connected to PC without downloading driver. It will come up as DCIM or 100SSCAM folder. If you tried to connect your camera to PC but it is still not recognized, try to download remote service for camera in samsungcamerausa.com under support and remote service.
SOURCE: Problem using my Samsung, Digimax D53
http://www.samsungcamera.com/popup/download.asp?prol_uid=2689&prj_uid=585
visit this link to get your manual for D53... thanks
SOURCE: Can't install software for D53 on my new Vista PC
If it is older software, it is probably not made to run on Vista Operating Systems. I would check the market for something Vista compatible. Samsung might even have updated software on their website for purchase. But you might want to do some bargain hunting around the net first.
Or you could always just connect the camera to the computer and copy the pictures into the "My pictures" folder on your computer. And with Vista's "Windows Image Viewer" (or something of that nature) you can do basic things to the photos, like adjust brightness, contrast, or saturation. You could also crop the photos, and more. The Vista provided image viewer is probably equal to what you could do to photos in the software.
There is no driver available for Vista for this camera
Here is link to all the software for the camera
If you are taking pictures off of a memory card, you can use a card reader and work with the pictures that way.
