Question about Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array
No sound from speakers
At the end of a three hour gig at a nearby golf course open house, suddenly we get no sound from the speakers. Even the CD player has no sound. We had two vocal mikes, a keyboard and a bass plugged in at the time. We were not quite a full volume.
The green power light is illuminated when power is switched on, but the red protect light does not flash when unit powered up and stays off. What has happened, an amp. problem?
  • 3 more comments
  • Anonymous Apr 01, 2009
    i have the same problem i dont know what to do i just got it a day ago too!!! help!! plaese its driving me nuts!
  • johnnyquest2 Apr 01, 2009
    this is driving me crazy i have the same problem and i just got the PA!! HELP!
    please help be more specific this is really driving me crazy and i just got it yesterday!! i have no sound at all and the protect light wont flash
  • Tony
    Tony May 11, 2010
    There may be circuit protection (fuses) inside the amplifier that protect each channel output. Have you checked if these exist and are good or open?
  • timx1386
    timx1386 Nov 29, 2013
    Same problem here -
    President:
  • 1,138 Answers
Page 8 of the owners manual explains this and suggests that if their procedure fails to take it into an authorized Fender dealer for service. The manual is dowloadable at Fender.com/support.
Posted on May 13, 2009
Peavey problems
It is impedance that matters. You can connect 1000w speakers at 1 watt amplifier as long as impedance (Ohms) is correct. You can not frie speakers with low power. It is the same as turning volume down (even to zero?).If it worked for some time then problem is in mixer itself and would have happened anyway. Could be just blown fuse or something. Does it show any "sign of life" ? LEDs etc?
May 04, 2017 | Music
We have four submixes that were working well, then all of a sudden the only way we could get sound out of the house speaker was to mix to the mono ''C' mix. Monitor seems unaffected. Any i
The first thing I recommend is to make sure that no mute buttons are pressed and no solo buttons are pressed. Explain a little more specifics about your setup and I can help you more. Sounds like some bad connections, bad cord, or something has blown. Lets stay simple starting out but, I need to know more about your setup, please. Don't forget to use phantom power for any condenser mics.I realize your problem is on the output side of things, just a couple of things to check before we start troubleshooting. Let me know.
Mar 29, 2013 | Soundcraft LX7ii 32 Mixer
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
Not functioning..
I would check it with a different instrument cable AND bass guitar. If you end up with the same results, it's a thermal issue with the amp and will require factory authorized repair. The amp heats up and the intermittent component starts failing....more heat, more failure. It's not an easy fix and your Behringer repair shop will have their work cut out for them with this repair.
Oct 29, 2012 | Behringer Ultrabass Bxl3000 300w 1x15"...
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
Peavey speakers making no sound
Try connecting them to another amplifier...you can use the speaker output of a guitar amp as a quick test. If the amp (and mixer) check OK, it sounds like you are about to become good friends with your local speaker reconing shop.
Remember...Distorted Audio Can Kill Speakers even at low volumes. It happens because sine waves become square waves. Google it for additional information.
Oct 24, 2012 | Peavey PR15 400w PA Speakers
Played samson 412 aura speakers for about 6 hours today with the volume at 1/4 of the way turned up.. the speakers became very hot and turned off by them selves.. I have them mounted on stands in a corner...
The volume setting on the speakers has LITTLE to do with how hard you are driving them. Your source might be extra hot and overdriving them. Read the specs on the speakers and use a sound meter to check your level. The speakers, being only 12 inch, should fill a room 20 foot by 20 foot to about 95 to 100 Db which you are only allowed 2 hours in MAX to prevent hearing loss. At 6 hours you should keep it down to 85 Db SPL. I know several deaf musicians that were exposed to high sound levels in rock bands... a deaf musician is kind of washed up.
Jul 03, 2011 | Samson Auro D412 2Way Active Speaker
I have just bought a PRX612M. When I play my digital piano through it at low volume there is a buzz which is most noticable as the notes volume dies down. Loud it sounds great but i would love to know what...
1000 Watts? Well, those are peak values. !000 watts RMS into a 12 inch speaker and it would smoke... this is some of our inflated advertising. But that is beside rhe point... now on to your problem: What you are having is a ground loop. You may have to do more than one thing to correct this here is the things to do in the order to do them to solve the problem:
1. Connect the piano and the speaker to the SAME power source or receptacle, even if you have to run an extension cord, three wire of course. Plug all of this ONLY into a grounded outlet, if your house has only two wire plugs, then you need to get an electrician to install a grounded receptacle.
2. Use Balanced lines. This means XLR or TRS balanced cables between the piano and the speaker. Use the 1/4 inch jacks output, not the RCA ones.
3. Since the AUX outputs do not support balanced lines, the next step require you use DI box. They are about $20 from Guitar Center and others. With very short 1/4 inch mono cable connect the piano to the DI box from the L/R mono piano to the high impedance input port of the DI and set the ground lift switch to "LIFT". Use an XLR to XLR cable from the DI box to the speaker. This last step if needed is the last thing in our bag of tricks to break the ground loop that can cause the buzz. Dirty power, if you have lamp dimmers can be a source of the noise.
Apr 06, 2011 | JBL PRX612M 12 Inch Two Way Self Powered...
JBL JRX115 producing very muffled sound even though graphics on mixer at normally used settings. Someone suggested we may have "popped" the horns. Is this potentially the problem. We have been running...
The speakers are rated 250 Watts. Driving with 600 Watt amps requires one to be careful of how much the volume is turned up to avoid damage. You MAY have damaged more than just the compression drivers on the horns but the voice coils on the 15 inch speakers as well. Further use could also damage the amplifiers. You did not mention what brand amps and it is possible they have a problem.
You best replace the units with ones rated for the power of the amps as restoring them on short notice for a gig is not practical.
Sep 12, 2010 | JBL Music
Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array Logo
318 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
