Question about Sanyo 4.4 cu. ft Counter-High Refrigerator, SR-4433S
MY FRIDGE WAS WORKING NORMALLY AND IT JUST STOP FREEZING BUT I CAN HEAR SOMETHING WHEN PLUGGED IT TO THE ELECTRICITY BUT IT DOES NOT WORK SO I NEED SOMEONE TO HELP ME OUT WITH IT. SOME PEOPLE SAY THAT THE PROPANE GAS IS FINISH THAT'S PROBABLY ONE OF THE REASON. THANK YOU IN ADVANCE
  • masibol Jan 22, 2009
    `Well... almost the same problem, my defer in that it doesn't make any noise.
    I poked my voltmeter a little bit, my problem has to be either the OverLoad Protection fuse or the Compressor according to the diagram at the back of the fridge.
    I would like to see a drawing that tells how to remove the part from the compressor case.
    If you are a tech an live in the Mountain View, CA area I would like to hire you at a reasonable rate.
    thanks
    masibol@gmail.com
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Your fridge most likely needs a refrigerant recharge , or a new compressor.
Posted on Jan 25, 2018
4 Suggested Answers
  • 1462 Answers
SOURCE: Compressor Does Not Seem to Start
feel the compressor. if warm then it is being powered up and symptoms point to a compressor fault. it is also possible that the compressor start device is faulty. remove cover over compressor electrics and check for any distressed componants
Posted on Jun 22, 2007
motor1258
  • 6674 Answers
SOURCE: not working on propane
Shut it off, (propane) and used compressed air to try and blow up that stack and clean out any rust that may be in there, as well as check for baffle hooked at top of stack, and hangs down inside the tube.
Posted on Jun 03, 2010
  • 2006 Answers
SOURCE: Fridge does not get cold during propane gas
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Posted on Sep 11, 2011
Amana Regrigerator Stopped Working After Power Supply Loss
unplug it and leave it off for an hour. then plug back in this may reset it. power coming back on can be higher than normal its always best to turn things off so when the power comes back on and you switch it back on its at the correct voltage.
Feb 28, 2018 | Amana Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Galaxy refrigerator
HI.TONY.try defrosting all first.it might work.normally if freezer ices up your fridge would stop working.in this case is the opposite.is the freezer ok?realistically it needs a visual check .fridge to freeze up it sounds like the thermostat .flaps sensor or board.hope this helps ali
Jul 12, 2012 | GALAXY Microsystems 25.4 cu. ft....
The refrigerator and the freezer are staying too cold. The temp controls are at the lowest possible and still things in fridge freeze. I can hear the compressor cycle of for a while then on for a while....
things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help out.....
Jun 09, 2011 | Refrigerators
Fridge freezer stopped working electrics are ok switches on but not cooling/freezing
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 10, 2011 | Samsung Refrigerators
I have a service upright fridge freezer about 4-5 years old suddenly fridge half stopped working. The freezer half still on and freezer is on but not freezing as normal all lights are on ( internal)
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | Refrigerators
The fridge works but the freezer, while cold, does not freeze
Hi, The freezer compartment is (logically) favored for cooling. There is a fan, normally between the back of the freezer compartment and the outside sheet metal that circulates the cooled air from the hidden coils to the refrigerator compartment.
When you hear the compressor is running, look for vents in the back of the refrigerator side and hold some wet fingers in front of these. Under normal circumstances, there should be an easily noticeable flow of air coming from these vents that represents the fridge's share of the cooled air. If there is none or is very little flow, the fan has either slowed (sticky sleeve bearings) or the fan has stopped completely. This isn't a dangerous problem since all modern electric motors are 'impedance protected' meaning that if the motor cannot turn, it still will not get any more than hot, it won't catch fire as they once would.
Thank you!
May 13, 2010 | Frigidaire FRS3R5EMB Side by Side...
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Freezer is defrosting
Many times, on a fridge with automatic defrosting, there is a sensor at the back of the freezer section (behind the plastic) that detects a freeze condition - sometimes these go bad, In normal operation, usually once a day, the timer sends a signal through this sensor and if it shows a frozen condition, it activate a heater (yes, a heater) in the freezer section that melts and defrost the coils. If this system stops working, the ice builds up and closes up the air passages to the fridge section, causing it to warm up, while the freezer section ices up!
Check for icing and maybe try defrosting a little by removing power for a little while. Move any food to another fridge while you are fixing it. The freeze sensors are easy to change, but be careful - electricity can kill. Always hire a professional if you have any doubts about your ability to perform the work yourself.
Aug 30, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
99 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Bailey's...
Bailey's...
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
