Question about Cuisinart DCC-1200 Coffee Maker
No Power I just purchased this this afternoon, unpacked it, plugged it and and set the clock. 3 hours later I went to make a pot of coffee and it has no power. It's not the outlet - I used other appliances in it and checked the circuit breaker too.
  • 944 Answers
I guess you have the manual, but here is the link if anyone else needs it; http://www.cuisinart.com/share/man/25_man.pdf the unit is still under warranty, so contact cuisinart on: 1800-726-0190. http://www.cuisinart.com/contact/ It sounds like there is probably something significantly wrong, not able to check without voiding the warranty - first check plugging the coffee maker into several other outlets, just in case it is the plug that is the issue, try wiggling the power cord at the machine end - make sure it is dry first in case it has a loose contact just inside, bet even if this is the case it still needs to be fixed. Apparently cuisinart are pretty good with repairs and replacements, but unfortunately you have to pay postage - maybe check at the store you bought it and see if they will do anything for you - most will if you ask right and have the receipt. Hope this helps :)
Posted on Mar 17, 2007
How do I set the delay brew?
hold delay brew button in with one hand while setting hour, then min.. Make sure clock has rolled over to AM if you want morning. Also make sure the correct time is set on pot.
Apr 04, 2011 | Mr. Coffee ARX23 / ARX20 Coffee Maker
How do you program?
Hello!
This could help
How to set the time:
1. Plug in the unit. Wait until the hour on the LCD starts blinking
2. Press the CLOCK button to set the correct hour
3. Press the SET button to switch to minutes
4. Press the CLOCK button to set minutes
5. Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
1. Press and hold SET until the hour begins to blink
2. Press PROGRAM until you see the tiny bell icon on the bottom of the screen
3. Press CLOCK until you get to the hour you want to start brewing
4. Press SET to switch to minutes
5. Press CLOCK to get to the minutes you want to start brewing
6. Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Please rate this answer. thanks
Nov 24, 2010 | Faberware FCP512S Cordless Electric Kettle
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
My coffee pot died during the night
It had nothing to do with the coffee pot. I blew a breaker!
Aug 30, 2009 | GE Coffee Makers & Espresso Machines
Cuisinart DCC2000/how to set it to keep coffee warm for 4 hrs
From my Cuisinart DCC-2000 Series Manual: The AUTO OFF feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours.
To program the Variable AUTO OFF:
1. Turn the function knob to "Auto Off". Press and hold the "Hour" button for 2 seconds. The clock display will start blinking.
2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the "Hour" and "Minute" buttons (see "TO SET THE TIME").
TO SET THE TIME:
1. Turn the function knob to "Clock".
a. SET HOUR: Press and hold the "Hour" button to scroll through numbers quickly. When number displayed approaches the desired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct hour, the default will be the last time set unless power is shut off.
NOTE: When the number count passes 12, the PM light will be displayed on the LCD.
b. SET MINUTES: Press and hold the "Minute" button to scroll through numbers quickly. When number displayed approaches the disired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct minute, the default will be the last time set unless power is shut off. To finish setting time, turn the FUNCTION KNOB to any other setting or simply wait until the numerals stop blinking.
(P.S. The picture of the coffeemaker shown above on this page is not the correct model I have as a DCC-2000. The picture shown has a coffee pot. The DCC2000 has a coffee reservoir and a dispensing lever for dispensing coffee into mug or cup.)
Jun 13, 2009 | Cuisinart Coffeemakers
How do I set the clock?
hit hour and minute buttons until it's on the right time and then hit program
Mar 21, 2009 | GE 106591 Coffee Maker
Programing clock on saeco coffee pot
You can get the instruction manual for your machine at saecooutlet.com, Click on user manuals and then select your machine.
To set the clock, hold the hour or minute button until the display flashes then adjust the time.
Feb 01, 2009 | Saeco TDCM15 Renaissance Stainless Steel...
Farberware FCP512S coffee pot instructions
Plug the unit in
Hope this helps
Sep 09, 2008 | Mr. Coffee ISX23
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
375 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Norman Worley
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
