I have a 3 yr old 55 inch Hitachi projection tv and the tv would not turn on, but all 3 leds on the front were blinking leading me to believe it might be the bulb burned out. I removed the bulb and indeed it had a physically broken filament. I replaced the bulb, but now the tv still will not turn on, but only the bulb led is now blinking. What should I try next?
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 04, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi 53FDX20B Rear won't turn on and LED's Flashing
I believe they are the voltage supplies for the TWO convergence IC's that this set uses(either STK-392-110 OR STK 392-150---THEY are interchangeable--but the 150 is a better device)
The easiest way to prove if this is your problem is to locate the two chips (black--2 1/2 inch wide X 1 1/2 inch tall with the STK number printed on them IN WHITE)
If someone unsolders all 18 pins on each chip--see if the set will turn on with them out of the circuit (you do not have to remove them--just unsolder both---If the set comes on the convergence will be very bad but you will know one of the chips is bad.
Also if you look at all the resistors around them (most will have location number RK46 etc) see if any of them are discolored or burnt. You find a burnt resistor and it is a sure bet onE of the chips is bad.
BOTH CHIPS NEED TO BE REPLACED!
A pretty easy repair if you have good soldering skills and I can tell you what you will need to do the repair.
If replacement of the chips fixes the set it just needs to be adjusted with the Hitachi remote and should not have this problem again for 5-8 years.
IF YOU HAVE QUESTIONS, do not hesitate to ask me---I am here to help people.
SD TECH
Posted on Oct 09, 2009
Testimonial: "Thanks for your help, I'll have to pull the board and take it into the shop tonight to try it."
ag66339
  • 127 Answers
SOURCE: I have been offered a 55 inch Hitachi Projection TV
Yes it is. A TV repair shop can replace the parts for less than $100.
Posted on Oct 22, 2009
asnowman
  • 788 Answers
SOURCE: The red power LED on my 4 yours old PT-47WX54J
If your Panasonic Television is blinking 3 times then you have a short on your power supply and the most likely suspect is your convergence IC’s.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts, and your will get a repair kit instead of just the IC's.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jan 31, 2010
SOURCE: How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Posted on Jun 09, 2010
My Hitachi tv will not turn on
My Hitachi used to eat Horizontal output transitors. I do not even know if your uinit has that anymore, but if that goes out the unit wont make the B+ voltage needed to power up the unit.
Sep 19, 2017 | Hitachi Televison & Video
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 04, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
The temp and lamp light start blinking when i turn on the tv and the screen is black and the lamp light stays on hitachi i think it is a 55 inch model # 55vs69a
CK the Lamp Fan to see if it is running ,If you are still running the orignal Lamp then replace it . Mats has them for $99.00
1-800-628-1118
Jul 10, 2010 | Hitachi 55VS69 55" Projection HDTV
55 inch tv shut off will not turn on any more
velvel535, since you do get the other led's to light up it could be that you have an operable power supply and the problem is more than likely in the horizontal deflection circuit' a shorted h.o.transistor or components related to it.If the tv does have a good power supply you will hear some kind of noise when you push the power key though this is not a sure indicator of a good power supply. some repair costs for a horiz out problem can run up to 290 dolls depending on the problem.Please leave positive feedback if i answered your question.thanks!
Aug 27, 2009 | Hitachi 55FX48B 55" Rear Projection...
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking lights and pwer down
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jul 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Little Green Light
Both Users:Please verify Model # and mo / yr built off the
back of TV............need for correct diagnosis............T.
Dec 19, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
