Question about Dell Latitude D610 Notebook
I JUST FORMATED IT WITH 1 GIGA RAM AND ALL DRIVERS INSTALLED AND WORKING BUT THE MACHINE IS TOOO SLOW
  • 4 more comments
  • giljay Dec 15, 2008
    its a intel centrino mobile tecnology 1.86 ghz 335mhz
    1 giga byte ram memory
    and it is showing 1.00gb ram right now
  • Randall  Trahan
    Randall Trahan May 11, 2010
    First run Disk Cleanup to clear out any of the old tmp files that may be slowing down your system. Then do a defragment compact your data on your hard drive. This should improved the performance.
  • Lavonia Ford May 11, 2010
    Your processor is fast enough.Do this for me...Right click on my computer and select properties.How much ram is your computer showing?
    What size of processor is on your system board?
  • 21 Answers
Try increasing the swap file size. Set a size roughly 3.5 times the available memory.
Posted on Feb 06, 2009
W3400 runs very slow, 64 bit, 2gig ram xp-pro
Your hard drive has the defective, there are bad sectors already in you drive, that's why it run slowly even though you formatted it.
Mar 27, 2012 | E-Machines W3400 PC Desktop
Someone gave me a sony vaio desktop pcv-rz26g without a hard drive or ram. i added both and installed winxp-sp3 along with every windows update. i am having a hell of a time trying to add this 'giga...
Hi Ryan,
Sorry to hear about your troubles, but I think I have something that can help you:
1. Don't shoot me, but if you haven't already, go to this link and download the package. You don't need the Giga Pocket update (is useless so I assume that is where you are having problems) BUT the MPEG encoder drivers are necessary.
2. Get the Giga Pocket app and all the frills for XP from here
3. Although I could leave it here, I know that a lot of problems arise when people install both the drivers and Giga Pocket app such as getting a grey screen for all your channels despite this whole process being such a pain. All you need to do to make it work is a little bit more work from a command prompt by registering the *ax files. Since you installed the HD, RAM and a new OS, I think you can handle it.
To register the Sony *.ax files (after installing the initial drivers and Giga Pocket):
Note: There seem to be a lot of *.ax files, so I am giving you the automated option. If you have issues and want to do each manually, let me know and I'll guide you.
1.) From the command window, type as follows:
cd "c:\Program Files\Sony"
dir /S /B *.ax
This will give you a list of all of the .ax files in all of the subdirectories.
2.) You need to copy this list into a text file. First, click the window icon at the top left-hand side of the command window. When the menu drops down choose edit-> Mark. Now you can drag the mouse to select the entire list of files. Don't forget to scroll up and start with the first file in the list. When you have selected the entire list, press enter to copy the text.
3.) Next, open Notepad and paste the text into a new document. Now use the search and replace feature as follows. First, replace all instances of c:\
with the following
regsvr32 "c:\
Then, replace all instances of
.ax
with the following
.ax"
4.) Finally, save the file somewhere easy to remember would the file extension .bat. For example, you could save it as c:\giga.bat
Now all you have to do is run the batch file that you just created. You can either double-click it or run it from the command window. To run it from the command window simply enter the filename by itself on the command line. When you run it, it will display a dialog box for each file that was successfully registered.
Jan 30, 2010 | Sony VAIO Digital Studio PCV-RZ26G PC...
Is pes 2010 work here ??
maybe your installer is problem...
try to reinstall
Oct 23, 2009 | Video Game Consoles & Games
Giga ONe hard drive reformat
You can format your giga one hard drive in MS-Dos mode.
1. Go to Start--> Run
2. type CMD to enter the DOS
3. select the giga one drive path (i.e. if it shows as E drive then simply write E: in DOS and hit enter.
4. type format
thats all that you have to do to format the giga one drive.
Jul 28, 2009 | Jobo GX1040 GIGA ONE Silver 40GB Portable...
Help for laptop L305-s5907
sounds like internal ram fried .due to a virus thats affecting Ram and cpu
Jun 28, 2009 | Toshiba Satellite L305-S5907 Laptop
GIGA POCKET TV TUNER NOT WORKING
PROBLEM SOLVED. APPARENTLY THE GIGA POCKET PROGRAM IS AFFECTED BY THE SONIC STAGE MUSIC PROGRAM OF SONY. I RE-FORMATTED AND DID NOT INSTALL THE VAIO MEDIA AND SONIC STAGE SOFTWARE ...
THE TV TUNER NOW WORKS FINE ....
I JUST USE WINDOWS MEDIA PLAYER AND WINAMP FOR THE MUSIC ....
NO REMOTE CONTROLS ... BUT THE TV TUNER WORKED .... ONCE MORE ....
May 19, 2009 | Sony Computers & Internet
Fromating Giga one
you need to go to the jobo site, find the driver/software/service link, in that you will find the giga one formatting tool, download and use that. i had the same problem when i purchased my original giga one, i used windows to format the drive - but as people find out windows is unable to format the drive correctly ie fat 32, and you then get an error message. in the formatting tool it tells you why what the different error codes are and error 1 means drive not formatted to fat 32, im not sure how old your giga one is but when i purchased mine approx 4yrs ago it never came with a proper manual and there was no support on the jobo site at the time. I think a lot of these minor problems could be avoided if it came with a manual and explained whats needed to clear the internal hard drive
Mar 19, 2009 | Jobo Giga One 40GB Portable Storage MP3...
Processor upgrade
just upgrade the ram to 2 gb
Dec 24, 2008 | Acer Aspire 5610-4648 Notebook
Canon 3300i prints / process very slow
These machines can print slowly for a varity of reasons. First and foremost is using the incorrect driver. The correct driver can be downloaded here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=6349
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
Nov 09, 2008 | Canon imageRUNNER 3300i Printer
Dell Latitude D610 Notebook Logo
Alun Cox
