Question about Swiss Air-O- 7135 Warm Mist Antimicrobial Humidifier Humidifier
Noisy ultrasonic humidifire
My humidifier humidifies ok but makes a lot of noise. There is no lose parts anywhere. The little grey circle that makes mist seems to have some crust on it which doesn't come off even with vinegar or special solutions. I've changed the cartridges and filters but maybe the water is very harsh here...
  • 363 Answers
The grey circle (diaphram) needs replacing. Try Maplin electronics.
Posted on Oct 01, 2007
SOURCE:
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Humidifier making noise.not steaming
This is an indication that the power supply has issues. You would have to take it apart to check and see what is wrong.
Mar 10, 2015 | Air Innovations Ultrasonic Digital...
Noisy start-up
If it is a vibrating motor noise, then some oil may help but make sureit doesn't drop into the tank. The little Motors used in these things have a limited lifetime and bearings and corrosion a of insulated iron plates that the copper wire of the motor coils wrap around do tend to corrode and lose their efficiency.
Otherwise, try a bit of foam padding to isolate the tank from the motor assembly - there might be some slight vibration there.
Mar 13, 2014 | Crane Evaporative Cool Mist Drop Shape...
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Model 800 Aprilaire steam humidifire I have
Follow manufacturer instalation instructions. Why risk your equipment and you family's health to save a few bucks and a lil trouble on the proper parts. Your family is worth it, now go do the right thing. :)
Jan 24, 2011 | Aprilaire 550 Humidifier
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
Jan 13, 2011 | Vicks Ultrasonic V5100 Humidifier
Pollenex HealthAire UltraSonic Humidifier SH50 need new washer
Sure. But if your homemade gasket leaks try a little 100% silicone caulking. It smells bad for an hour or so but it will help. If you use the silicon make sure you allow it to thoroughly dry before you get it wet or it "will" leak.
Good luck
HVAC Teacher
Feb 18, 2009 | Aprilaire 700 Humidifier
Noisy humidifier
A noisy humidifier may be the result of an unlubricated fan motor or a drive mechanism clogged by debris. Periodically clean the water reservoir, fan, and nozzle to ensure that they are clean and working properly. To keep your humidifier working smoothly and efficiently, lubricate the fan motor bearings with SAE #20 oil. Be sure to consult your owner?s manual for proper care and maintenance procedures. If it seems loose, vibrating parts are causing the noise: 1) Disconnect the power. 2) Remove the cover and look for any vibrating parts. Tighten screws, if necessary. 3) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor's bearings if suggested in your owner's manual. 4) If it still makes noise, call an appliance repairperson or take the unit into an appliance repair shop.
Jan 18, 2006 | Honeywell HCM530 Humidifier
Humidifiers Logo
557 people viewed this question
Top Swiss Humidifiers Experts
Paul Carew
Dennis Webber
Marvin
Marvin
Are you a Swiss Humidifier Expert? Answer questions, earn points and help others
