Question about Motorola Mobility RAZR V3
Battery not holding charge
Razr3 battery new in phone 2 1/2 years ago, but started to show low charge after one or two days. This is after an all night charge. Don't talk on phone much sometimes days. Brought a new battery, but does the same thing. ?????
  • 2 more comments
  • dragonman Dec 15, 2008
    1st 21/2 years the charge lasted 2-3 days now it only lasts the same day just having on and not calling.
  • dragonman Dec 16, 2008
    the original battery was ok untill recently. the new battery is worst than theold.
    Original battery was ok until recently. The new battery is worst than the old battery. Why?
  • Guitarman62 Dec 25, 2008
    I have exactly the same problem. My V3 is now 3 years old and no longer holds much of a charge. I bought a basic Nokia in Bankok in July costing only £14 and this performs far better! Reception too has deteriorated dramatically so I bought a new battery online (non-original brand). No better so I complained to the battery provider and was sent a replacement. This was still no better so I visited Carphone Warehouse today and was told that it probably wasn't a battery problem. They advised that phones are not designed to last much more than a year!! I could check it in for repair but that wouldn't be cost-effective. Try downloading any available configuration updates they suggested. I connected my V3 to the internet via the supplied phone/USB cable, opened 'Motorola mobile phone tools' and found 3 updates that I have have now installed. I'll see if this has made a difference over Christmas and if so I'll let you know. Failing this it's a new phone for me I believe. Fingers crossed.......
    Ron
    Problem Solver:
  • 17 Answers
That sounds like typical battery life for that phone.  When I owned one that's what I got on the weekends when my call volume was lower.
Posted on Dec 15, 2008
  • DService Dec 15, 2008
    Batteries do wear out over time and some manufacturers don't have as good a quality as others. See Sony batteries.
Garmin 260 now failing to charge and shuts itself down
If the unit is only a year old? then I would suspect that the charger has a problem that has damaged your battery. Do you use an external power continuously?
Try a different charger or if you have a meter make sure the charger is putting out close to the specs on it. Try using the usb cable to charge it.
The low battery and shutting off are typical of a battery that won't/can't hold a charge. That is typical after 2-3 years plus but not one year. It can also be indicitive of the charging circuit needing to be reset. The problem is it needs to be started and run long enough for it to recognize the reset command. To do this, hold your finger on the bottom right corner of the screen while powering the unit, until it asks if you want to reset it. That might get you running.
While I would be suprised at the battery going out within a year or so it is not unheard of. You may have to replace the internal battery pack. The unit is new enough your only source is probablly going to be Garmin. They might replace the battery under warrenty or out (if you talk nice).
Jul 24, 2009 | Garmin nuvi 205 GPS Receiver
Low battery won't charge,change battery,now dead won't charge????
I had the same problem so I got a new battery & separate charger to charge both new & old, then replace as required.
Nov 05, 2017 | Uniden Cordless Phone exai398i
Uniden TRU8885-2 Restarts every time an incoming phone call, start showing the Welcome message ....
YOUR batteries are bad and not giving full current to phone.Clean charging contact and see battery gets full charge. IFthe battery indicator will show full charge due to voltage but once if you remove battery and put it again indicator will be minimum. then replace batttery.
Oct 07, 2008 | Uniden TRU8885-2 Cordless Phone
Motorola i850 will not charge completely
check may be the charger is bad if not so lose your phone, at the botton, at charging port side u see two seperate leg re-solder it.
Oct 07, 2008 | Motorola Mobility i850 Cellular Phone
Out of range, buttons don't respond, battery won't hold charge
when you have a problem with anything under warranty, you take it back for new units or a refund and anything under 12 months old is under warranty
if you have lost the receipts get a copy of your bank statements as that shows where it was bought , how much it cost and when
That is a legal document to trigger a warranty action or refund
Mar 10, 2017 | Uniden DECT 6.0 Cordless Telephone...
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
THAT IS AN ERROR ON YOUR BATTERY METER YOU NEED TO DO A HARD RESET AND IT WILL CORRECT THIS PROBLEM...*2767*3855#
Oct 28, 2007 | Samsung SGH-D900 Cellular Phone
Samsung a570
nope i had 1 an i threw it in the wall twice it comes up and work but even on a full bat it shows low bat....(it never dieed nor turned off)
Jan 02, 2007 | Samsung SCH-a570
Motorola Mobility RAZR V3 Logo
127 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
