Question about GE DBSR453EBWW Electric Dryer
Motor not strong enough
My wife said the dryer made a noise but was the drum was not turning. I took the top off and the drum would not turn but would start when I assisted by turning the drum.
I could see the red from the heating elements. When I opened the door, the drum stopped but the heating elements seemed to stay lit.
Any ideas?
  • 108 Answers
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Posted on Dec 15, 2008
The dryer was making a horrible squeaking sound, the drum stopped turning, so i took it apart, but the belt was not broken and the wheels seemed to be ok, so i put it back together and the drum still...
Sounds like your problem may be a belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Aug 25, 2010 | Maytag MDE9206 Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer won't start spining the drum
The belt is the likely culprit, you have to look inside to see if it is the belt
May 03, 2009 | GE DWSR405EBWW Electric Dryer
My dryer is acting weird
your dryer motor is no longer strong enough to turn the drum,how old is the dryer?mike
Apr 04, 2009 | Kenmore Dryers
Motor is fine but drum won't turn. What could it be?
is there a belt to turn the drum - if so it may need to be changed.
Jan 04, 2009 | Kenmore 73952 Gas Dryer
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Starting problems
the motor is bad i run in to this a lot in the field the motor isn't strong enough to pull the drum but it is good enough to pull itself
replace the motor and this should take care of the problem good luck
Dec 17, 2007 | Maytag Performa PAV2200
GE DBSR453EBWW Electric Dryer Logo
113 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
