Question about Insignia IS-LCDTV32 32 in. Television
Insignia 32" LCD32 TV Red,Green,Blue,White,Black Screens- Cycling
I have a 32" LCD Insignis TV that cycles through red, gree, blue, white and black screens. No picture, no sound. S-Video doesn't work, nor does antenna input.
Any ideas?
  • 5 more comments
  • edrenckh Dec 27, 2008
    After the TV was off for a week or so, it seems to be working.
    What would cause the TV to go into what I would call a 'test mode' and I could not get it working.
    Could this be the capacitor issue?
    Any ideas appreciated.
  • edrenckh Jan 01, 2009
    I turned it on again today. It is back to the original problem. Cycling through the solid color screens.
    Does the original solution still match up with this condition?
    It is the Insignia LS-LCD 32. Manufacture date September 2007. It is a replacement for my original one that went bad last year....
    The TV turns on and off with the remote and changes channels.
    I can hear the program(s) that should be displayed, but no display. It only cycles the entire screen through the different colors.
    No warranty, already called Best Buy prior to posting the problem.
    Is this a problem that I can just swap a board out?
  • edrenckh Jan 04, 2009
    What part do I need to fix this problem?
    What would be the part number for the mainboard?
  • 3 Answers
This could be caused by 1 of 2 things one would be a bad main board or a bad ir board both can be replaced easily. And you can find parts cheap buying used parts or by buying a exact model with a broken screen. Or feel free to call us at REDS REPAIR at 870-421-1294 we can find you a broken model and send you the boards. Thank you for choosing fix ya.
Posted on Jan 04, 2009
  • Insignia Master
  • 19,396 Answers
As stated, the most likely is the LCD controller board, that is the main board inside your TV, or a dafective LCD ribbon cable (color bands alternating).
However a short to the chassis, or a short on one of the other boards (inverter, tuner, IO etc.) can always cause erratic symptoms of this kind.
The TV should be tested by a technician before replacing the main board.
Here you find all parts for your specific model (32).
    Genius:
  • 1,550 Answers
You need to replace the main board . Turn off and turn on can solve your problem for short period . For complete fix you need to replace the board and you can get board from partstore.com
    Sniper:
  • 108 Answers
DEAR SIR
KINDLY TAKE UR TV TO SERVICE POINT. THERE IS A PROBLEM WITH RGB COLOUR (i.e: liquid display problem)
regards
murali
Posted on Jan 01, 2009
  • 10,594 Answers
Let me know exact model number of 32" LCD TV.
Seems its main board is cause of trouble.
Does TV respond on remote?
Posted on Dec 27, 2008
  • Shahid Electronics
    Shahid Electronics Jan 01, 2009
    TV requires LCD Controller board replacement.
    You can get subject board from Shop Jimmy on reasonable price. and its very easy to swap this board.
    Board picture is also on above website link.
    Good luck and Happy New Year.
    Shahid Electronics Jan 04, 2009
    Have a look on all available parts of your TV in Shop Jimmy.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Often, this type of fault indicates a defective digital display module. Alternately, this could be brought about by absence/low B+ to the digital display module from the power supply board. Common problem with the PSU are 3 X 680uf at 35 volt capacitors at the top left of the PSU board.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 23, 2008
  • Louie  Role
    Louie Role Jan 02, 2009
    To your renewed concern:
    Cheers.
    Genius:
  • 2,920 Answers
There are 4 capaciters one in each cormer inside the back of the tv to see if any of them are popped up. if they are then they need replaced
  • 1 more comment
  • Ronnie Houston Jan 01, 2009
    you have several bad capaciters preventing the tv from working call a repairman in
    yes and either way you will need a repairman and if you still have a warranty thats even better but yes you have bad capaciters
    its going to be more that just a board...i dont think you should try to fo it on your own as you may end up making it worse than it is now...its your decision but i would call a tech out to fix it have a happy new year sorry it has to be so hard about the tv
Insignia ns lcd32
Check the connecting cable to display paned and its T'Con board [LVDS cable] for any loose contact with its either end sockets. Reseat it once and check. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Jul 12, 2013 | Televison & Video
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
I need the diagram for 1993 honda accord for radio i am installing a jvc cd player and i dont have the right adapter so i cut the origanal plug and now need to know the color codes for the wiring
this the wiring for that car--
constant power-white/green
ignition--white with red
ground-black
dimmer-red/black
left front spk-blue with green-+
left front spk-ghray/black -
right front spk-red/gree-+
'' spk-brown/black-
right rear spk-red/yellow-+
'''''''''''''''''''' spk-brown/white-
left rear spk-blue /yellow-+
'' spk-gray/white -
antenna you done need you antenna is in your window
Jun 25, 2009 | Car Audio & Video
Insignia 42" 1080p flat panel tv
you have lost your chroma (color) circuit the sepia you are seeing is just the black & white picture black and, white is adjustable from red to blue to green tint so; your sepia is an overloaded red circuit i could fix this but, i'm here and, you're there so take it to a serviceman it should not cost much more than $100
Apr 30, 2009 | Insignia 42" LCD Flat-Panel HDTV
Lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
Jan 01, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Insignia 32-lcd black screen and thin colored lines vertically
Most likly the signal connector is loose or dirty. (input) this would cause the red, gree, blue or a combination to not be connected.
Mar 22, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
412 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
