Question about Bose Lifestyle 38 System
TV audio through Bose Lifestyle 38
I have a Vizio 32" HDTV whose audio I would like to come out of the Bose system - I have connected the audio out from the TV to the media center indicating TV - however, I am unable to get any audio out of the Bose Lifestyle 38. The same problem is true for my VCR - I have connected the VCR video and audio signals to the appropriate slots in the media center and I have the same problem. Any ideas for troubleshooting would be great.
Thanks,
Easwar
  • esriniv Dec 15, 2008
    Thanks. THis was kind of helpful. A couple of related questions:
    1. The TV audio started working when I set the Lifestyle setting to VCR. Does anyone know what may be wrong - could I have set up cables wrong?
    2. None of the codes on the Lifestyle offered seem to work for my Vizio TV. Could this be causing the problem.
    Thanks,
    Easwar
I have Bose Lifestyle AV48 trying to hook up on my Sony TV Wega , picture wont come out but i have sounds . pls help with connections.
Jeff N
Posted on Mar 27, 2011
    Scholar:
  • 107 Answers
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Posted on Dec 15, 2008
  • Quang Viet HUYNH
    Quang Viet HUYNH Dec 16, 2008
    1) Yes I think your cables should be on TV input at the rear of Bose system then on the Bose's remote or front panel of AV 38 you select TV
    2) You need to bring your AV38 to Bose or Bose service center to update the new software for Vizio remote control by Bose' remote
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
My HDTV does not have RCA audio out option to connect to my Bose Lifestyle 12 surround system. Can I connect the Directv box directly to the lifestyle12 system to get surround for the TV? I would do...
Just make sure that you are using compatible connectors and that your signals are compatible. Ie. analog out to analog audio input, digital audio to digital audio input.
Sep 21, 2017 | Bose Lifestyle 12 System
We have a bose audio system w time warner cable on vizio 1080p 42" tv. audio went dead. bose about two years old
did you check the audio connections? do your audio rec / amp have any fuse(s)? the tv still have sound? is the jacks on the TV external / fixed .... once you have checked all this and still no sound before you call it.......... I would unplug everything and start from scratch and reconnect before I throw/buy a replacement.......... good luck
Jan 17, 2011 | Vizio L32 32 in. LCD HDTV
The volume control on my Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
Nov 28, 2009 | Bose Lifestyle 38 System
We want to hook up an HDMI dvd player to the tv and have the sound come thru the Bose Lifestyle 38 (older model, did not come w/the HDMI converter that the 48 has or newer systems come with). We are not...
The best way to do this is to take your OPTICAL AUDIO OUT from your TV - (if it's a newer TV) - plug it in to the OPTICAL AUDIO IN on your BOSE system, then use the 'TV' source on your Lifestyle 38 to get the sound from. I have sound for X-Box, DVD player, Blue-Ray Player and Wii being pushed through the TV back to the BOSE and it sounds great. I don't have to change the source on the BOSE very much either - except when I listen to stored music!
Sep 27, 2009 | Bose Lifestyle 38 System
Can't get sound on tv but dvd and radio work.
Sounds like an install problem. All of your inputs (audio and video) should run through the BOSE and then only the video out needs to run to the TV. In this way the BOSE is the sound source for everything
Aug 30, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 38 connection to TV doesn't work.
Is your tv hooked up to your cable box or satellite with an HDMI cable? There are several ways to input to the TV.
Aug 30, 2009 | Bose Lifestyle 38 Series IV DVD Home...
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
No audio from my tv which comes through my Bose system
Try using a Lifestyle® VS-2 video enhancer to connect your components to the bose system to get proper & enhanced output.
check out details from www.bose.com
Apr 15, 2009 | Bose Lifestyle 38 System
On my Bose Lifestyle 38 color is different.
Try a different SCART lead, if not try connecting to a different SCART slot on your TV.
If the problem persists I'd contact bose and have them repair it, its not worth taking apart a three grand system if you are not sure what you are doing.
Nov 27, 2007 | Bose Lifestyle 38 System
Bose Lifestyle 38 System Logo
1,016 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
