Question about Whirlpool RBS305PD Electric Single Oven
I don't have the booklet; want to use self-cleaning feature
It is a Whirlpool single wall oven, probably 5 years old.
  • Whirlpool Master
  • 3,463 Answers
Try:
wwwwhirlpool.co.uk.
Posted on Dec 15, 2008
I have a wall oven that is 15 years old and it's making a loud noise, after it's turned off. This has never happened before.
Don't burn your house down! Get a new wall oven. FYI Sears no longer sells Whirlpool.
Nov 10, 2017 | Whirlpool Ovens
Whirlpool wall oven glass door cracked+self cleaning feature does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 12, 2010 | Whirlpool Ovens
I used the self cleaning feature once on a built in oven. After that it doesn't work. Why?
I used the self clean feature on mine and found out, to late, that it gets so hot that it burns out some of the electrical components. I suggest NEVER use the self clean feature
May 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
After cleaning, the oven read out says that it is
maybe a thermal fuse on the back of the oven blew out. some of these wall ovens had a retrofit kit to help prevent this from repeatedly happening when the self cleaning was used.
Jan 09, 2010 | Whirlpool RBS305PDS Electric Single Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven will not heat after self cleaning
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Dec 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Oven not heating
heatman101
Nov 16, 2008 | Whirlpool SB160PEE Gas Single Oven
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Whirlpool RBS305PD Electric Single Oven Logo
70 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
