FixYa.com
Tags:
Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL
How do I fix the problem of my old hard disk drive...
By Cornish - usenet poster
How do I fix the problem of my old hard disk drive not being recognized as a system disk after replacing my old 486 motherboard?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 08, 2005
Helpful (85)
jessie25
jessie25 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Please don't do anything which would write to the drive. Your hard disk parameters in the CMOS setup on the new motherboard are probably not set the same as they were on your old computer. The new board is probably auto-detecting the drive and setting the parameters so they differ from the 486. My first guess is the 486 motherboard doesn't support Logical block Addressing (LBA) and Disk Manager or EZ Drive are installed on the old drive to implement LBA. Try to get the disk parameters off the 486 motherboard. You can get at the 486 by plugging in a power supply, CPU, memory, video card, and keyboard. It doesn't have to be put back in the case. Just make sure the bottom of the board is protected from shorting-out. Then go into the CMOS on the new motherboard and set the drive parameters so they are identical to the old motherboard using a user-defined drive. Once the old hard disk is operational, may then be possible to remove Disk Manager or EZ Drive and change the CMOS Setup to support LBA. The hard disk drive should be backed-up before attempting it.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 25, 2007
Not Rated (0)
jiddi
Rating: 80%, 2 votes
I successfully backed up the 4.3gb seagate hard disk on another machine (x) before i tried to format the drive to get rid of the numerous viruses that had infected the drive. unfortunately when I was reconnecting back the drive to the (x) machine after resetting the jumpers, i did not notice that the machine was not completely off as it seemed to be the case but rather in the standby mode. the drive went dead on he spot. the motor does not spin and there is not any sign of life in the drive. what could have happened? how can I correct the problem and recover my data?
This Problem Also Relates To: Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive Compaq (349239B21) 250 GB Hard Drive IBM (IBM60GB) 60 GB Hard Drive Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive LaCie d2 (300769) 200 GB Hard Drive LaCie Big Disk Extreme 500 GB Hard Drive LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB
Can you Help with these Hard Drives problems?
Hard Drives
External Corrupted
exactly it was say: F:\is... Answer This...
Smartdisk - Peripherals - HARD DRIVE,...
DEAR SIR I HAVE JUST
dear sir i have just bought one... Answer This...
how to make bad sector in hard...
hello how do the the code of... Answer This...
i have hdd regenerator but the...
i have hdd regenerator but the... Answer This...
EXTERNAL HARD DRIVE
elements power d external drive... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
