Question about Toshiba Satellite A105 Notebook
I have to hold down keys for 2-3 seconds to type. How to correct?
Keys type too slow.
  • rona1012 Dec 15, 2008
    no Ati hotkey poller listed.
  • 827 Answers
It might be due to a service called "ATI Hotkey Poller" running
which is intermittently slowing the keyboard typing down.
To disable it in Windows XP Home:-
Go to Start->>Run->>type "msconfig"->> click the "Services" tab->> uncheck Ati Hotkey Poller->> Then Ok, then Restart computer.
hope this helps
chris
ziraffa@hotmail.com
Posted on Dec 15, 2008
  • chris grams
    chris grams Dec 15, 2008
    Then I can only recommend doing the same for the CPMService.exe, although that tends to work on Dell laptops. press control-alt-delete and look in the task manager to see if it is running.
    if not then either, there are too many programs running at startup, or you have to get the latest graphics card drivers for your laptop.
    That's me all out of ideas, mate.
    good luck
    chris
Cat sat on keyboard. not a limerick... keyboard slow to respond with arrows and typing. Also light on top LHS under '1'... what is that ?
Hold down the shift button for a few seconds to disable sticky keys. This is a windows feature to help people with disabilities and is activated and disabled by holding the shift button down for a few seconds. You can also disable it under start menu/programs/accessories/accessibility
Jan 22, 2015 | HP Compaq nx9030 Notebook
Tip
How to reset most Kenwood radios when you forgot your password
Theres several types but here are the top three.
I use type 2 more than any other.
Type 1 During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears). Then using your remote enter your code.
Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Then using your remote enter your code. ------------------------------------------------------------------------------------------------------
Type 3 Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key * Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key * Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key * Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the AM/FM mode!
Post replies :)"TRACK UP BUTTON" for 3 seconds.. and youre done.
on Sep 22, 2011 | Car Audio & Video
My phone wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 05, 2012 | HTC Vivid
I have a jensen 321 and im trying to program it to a mitsubishi
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Or if you need to type in a code. MITSUBISHI Codes: 004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
May 04, 2011 | Jensen JER-321 Remote Control
Have a universal remote but lost paper work to type code for tv. Bought a universal remote
Try doing these steps so you can search the codes for your tv.
1. Turn on the component
2. Press and hold the TV key.
The illuminated on-off key turns on and stays on
3. While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5. Release both keys. The illuminated ON-OFF key remains on
6. Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks, and the next code in the list is sent. This process continues until all of the codes in the code lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON-OFF key blinks four times and turns off, all codes have been search. The manual code search method is exited.)
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be saved.
8. To confirm that the TV is programmed with the correct code for max functionality, test the TV. Attempt to control a variety of the TV's functions with the remote. If some of the features of your TV do not work try programming the remote with a different programming method. Be sure to retrieve the code your remote programmed.
Jun 11, 2010 | Jensen JER-422 Universal Remote Control
I need code for kenwood kdc w707 can anyone help
There are a few types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Type 2
Type 3
Model# DPX-4020 and DPX-4030
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Aug 31, 2009 | Kenwood KDC-W707 CD Player
What is the lock code for kenwood - kdc-x589
There are afew types of override procedures for Kenwood.
Type 1
Type 2
Type 3
Jul 23, 2009 | Kenwood KDC-X589 CD Player
Lost code for my kenwood kdc-w707
There are 2 types of override procedures for Kenwood.
Type 1
Type 2
Type 3
Apr 05, 2009 | Kenwood KDC-W707 CD Player
How do I use lower case letters in a text?
If your Tracfone has an uparrow on the zero (0) key, after entering a character, IMMEDIATELY hit the 0 key.  The phone will change the case of the previously entered character AND change case for subsequent entries.
If you're too slow typing the 0 key, you'll get the characters assigned (0, +, etc.) to that key.
Mar 11, 2009 | Motorola Mobility TracFone® V170 Cellular...
Types wrong characters
If the typewriter is typing letters or symbols that you do not type, it is usually because the Pitch Selector is set to "PS". The pitch selector is on the left hand side and has the numbers 10,12, 15 and PS. Place the selector on 10 or 12 and you will be OK.
Also, check to make sure your printwheel is installed properly. Remove it and put it back in to make sure.
Another thing you can try is to clear the memory. To do this, turn off the machine. Place a piece of paper in the machine sideways. Hold down the MAR REL key and while holding it down, turn on the machine. Wait 2 seconds, then let go of the key. The typewriter will start typing. Shut the machine off after about 15 seconds. Then turn it on as usual. This will clear the typewriter's memory and unexpected charaters should not happen anymore.
Jay @ www.granadahillsbusinessmachines.com
Aug 20, 2007 | Swintec 7040 Typewriter
Toshiba Satellite A105 Notebook Logo
305 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
