Question about Mitsubishi CS-13103 TV
NO PICTURE NO SOUND, NO POWER
MITSUBISHI MODEL 3103 R
I have a 52" Mitsubishi Lt-52244 TV which has sound, no picture but has images with the flashlight test. Which board/s should I replace?
That is an older model set that still has the backlight inverters. It may be one of those and it may be the power unit. Mitsubishi LT 52244 TV Parts
Feb 19, 2018 | Mitsubishi Televison & Video
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
No picture
Lamp life for this model is 2 years or 2000 hours, less if a non Mitsubishi lamp is used, sounds like a bad lamp.
Dec 22, 2012 | Mitsubishi WD-52531 Television
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
Goodluck..
May 01, 2008 | Televison & Video
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Televison & Video Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
