Question about RCA L32WD23 32 in. LCD HDTV
L32wd22 power supply
I have a l32wd22 lcd with a bad power supply and need to find schematics or the part # and manufacturer of the supply.
  • Anonymous Jan 02, 2009
    i have a popped resistor on my power supply logic board, i can only make out one band of the resistor which is no help and to this day can find a new power supply.
Which resistor do you need the value of?
Posted on Mar 21, 2009
    Problem Solver:
  • 11 Answers
I think I have one of these power supplies in my bad parts bin. If you will shoot me a digitl picture of the power supply and a close up of the bad resistor, I will see if I can give you a value. jryduke@intergate.com
Posted on Jan 05, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your requirement, pls try:
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
When i turn my 32'' rca flat screen on the red light is flashing but it would not come on ,what is causing that to happen ?
Power Supply problem, had the same problem, could not find a Power Supply board replacement even on ebay. They had a capacitor replacement kit, here on ebay http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Used that, and it worked.
Dec 11, 2011 | RCA L32WD22 32 in. LCD HDTV
Our tv when itis on for a while some times the picture freezes an then goes blank an a loud hissing an squeech sound we have to unplug it to turn it off.
Hissing sound normally from Power Supply unit(PSU), usually from Transfomers in the PSU. Usually caused by bad capacitors. Try this capacitor replacement kit, on ebay only $15. http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Could not find any PSU board available at the moment, but have tried that kit and it works.
Nov 30, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
Does not power up
It can be the power supply board is bad due to bad caps or blown components, it can also be the Main board is not sending the ON signals to the power supply. It will need torubleshooting and parts.
Boards: http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L32WD22
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 04, 2011 | RCA L32WD22 32 in. LCD HDTV
My parents have an RCA model L32WD22 it made a loud pop quit playing but the power light still comes on
jdc432002
That POP was the power supply. Take the unit to a service center and ask to have it fix, Don't tell em I said it is a power supply, Just ask to have it fix. They will call to say that it is not repairable. So you take the work order and then you call 1-877-297-8391 and they will give you another LCD tv
PS make sure you get or have the copy of the work order
Jun 10, 2010 | RCA L32WD22 32 in. LCD HDTV
Tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Mar 17, 2010 | RCA L32WD22 32 in. LCD HDTV
My L32WD22 doesn't seem to be getting any power.
tnbanderson,
Pls take your tv to a tv service center and ask them to fix it. They won't be able to. So you make sure the make a workorder. When you get that order, you call 1-877-297-8391 and they will give you a tv
Feb 03, 2010 | RCA L32WD22 32 in. LCD HDTV
My rca l32wd22 will not power up what do i do
First place to look is the main power supply module for simple thing like fuse, then look for 5V standby, you must have at least this standby voltage. This 5V (should always be there with the TV on or off) is supplied to the main board so when you turn on the TV, the main board will send the ON signal to the main power supply to supply voltages to other circuits.
Nov 03, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD23 32 in. LCD HDTV Logo
1,344 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
