Question about Kenmore 71510 / 71511 / 71512 / 71514 / 71519 Gas Kitchen Range
Adjustment for in house ng regulator
I installed a small natural gas heater in my garage and it goes out after about 10 minutes of use. i never adjusted the regulator being used by the furnise. how do i adjust it up
    Sergeant:
  • 359 Answers
If this is a new heater make sure the connection is tight to thermocouple and there is no draft that is blowing the flame away from thermocoupling causing the problem as far as the adjustment i agree with ray
Posted on Dec 15, 2008
  • 108 Answers
Don't adjust the regulator. Problems with the regulator are rare, and if you don't have the special pressure gauge you cant safely adjust it anyway. Your problem is with the thermocouple. This shuts off the gas valve if the burner goes out. Replacements can be found at Home Depot.
Ray
How to Convert to NG
You have to contact the manufacturers rep in the community to verify that the particular model of Dayton heater has the capability of NG to LP conversion. If it is, the natural gas kit will include a new set of brass 'spuds'...typically referred to as 'orifices'....for the main burners. The size of the hole will be considerably larger because NG contains less btu per cubic foot than LP gas.
There will be a replacement pilot orifice for the pilot assembly. Removed and installed usually a 1/2" and 7/16" wrench. This orifice will also have a larger diameter opening.
There should be a regulator to match the 100% redundant gas valve that is in your heater. Note though, that there may be several regulators in the kit to match any one of several brand gas valves that could've been installed on your heater....Robt Shaw, White Rodgers, Honeywell. They will NOT interchange with one another. Follow the directions closely to ensure installation is done correctly...you are working with a volitile, explosive gas !!!!
There may or may not be a set of air shutters to fit over the ends of the burners for primary air adjustment. Natural gas may require a bit of air adjustment to get the proper flame.
Thoroughly leak test everything when done, then leak test again.
If you feel you are in over your head, you probably are so contact a reliable service organization to do it instead. But at least you now have an idea of what is involved.
Aug 21, 2014 | Dayton (4LX45) Gas Heater
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
I have two Mr. Heater 20,000 BTU natural gas units. The first unit was purchased last Christmas and installed in February and works well. Very little smell, etc. The second unit (Model MHVFB20TB...
it is possible that the units are different gas in use
one is LPG and the other is natural gas
A mistake from the suppliers warehouse
as gas is a very dangerous product , I strongly suggest that you get in an accredited gas fitter to properly diagnose the problem for your family safety
Oct 11, 2017 | Mr. Heater H25N
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
I want to connect the unit to the main propane
First of all I am only concerned with your safety when I ask you to only have a qualified service tech install this heater for you. PROPANE is very dangerous if you aren't well trained in the operation/installation of gas fired equipment.Natural gas isn't quite as dangerous as it is lighter than air and will dissipate easier. Propane is heavier than air and will pool in the lowest spaces and collect there. To answer your question, yes most regulator can be adjusted, but again only by a qualified service tech because he needs to adjust the gas pressure to the equipment rated gas pressure specs. Again I am only concerned for your safety.
Nov 28, 2009 | Dyna-Glo RMC-8001SS Heater
My Bosch on demand water heater won't stay lit
DO NOT try to adjust gas pressure unless you have the appropriate tools and gauges to do it right. You don't want to burn your house down.
First make sure all of the gas valves are fully opened. If that checks out and the problems continue, call an HVAC technician or your gas supplier to have them evaluate the adequacy of the supply line as well as the gas pressure at your appliance. Go with whatever they say or ask you to do.
May 19, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water temperature varies while useing the hot water during a normal shower. jg
Try this before replacing the shower diverter valve.
If this problem is isolated to the shower only, then I would suggest that the shower diverter valve is equipped with an "Anti-scald" safety feature that can not be adjusted, however the temperature regulator/thermostat on the water heater can be adjusted to a lower temperature so as to not activate the the "Anti-scald".
Feb 20, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H NG
I hope this helps!
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/1600HTechSupport/Troubleshoot/tabid/1094/Default.aspx
Copy and paste to google search engine!
Jan 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Kenmore 71510 / 71511 / 71512 / 71514 / 71519 Gas Kitchen Range Logo
145 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
