Question about Microsoft Xbox 360 Console
Xbox freezein Whenever i boot up my xbox 360 it runs for a few minutes then the screen just freezes!!!! Most of the time when i turn it off let it cool down i dont get the 3 red lights i have a high defention tv i put it on 720p and it worked for a little while longer but still frezzes can any1 please help mee
  • Anonymous Jan 28, 2009
    The Xbox will come on but the game will point to a certain point and then the screen freezes. It however will play dvds but the games freeze up.
  • 124 Answers
Thisi s probably a precursor to the RRoD. Basically had the same thing happen to me a few weeks ago. Call MSFT (800 4myxbox) and tell them you have the rrod and you'll get it fixed for free.
Posted on Dec 15, 2008
Screen goes black whenever I press continue
check for game updates and if they don't help then u should
delete and reinstall the game
Jul 03, 2012 | Ubi Soft Shaun White Skateboarding for...
When i press start on the main menu it says (Loading settings "settings" from hard drive. Please do not turn off your xbox 360 console...) and it freezes, how can i fix this?
Ok I have seen this issue many times before , first unplug the console . Disconnect the power cable , a/v cable , controllers , any usb devices , & finally disconnect your hard drive . Now let the system sit for a few minutes , then plug in just the power , a/v cable , & a controller . You should be able to boot your Xbox 360 successfully now . At this point you can either connect your hard drive while the system is running or you can turn it off & connect it . This should fix the issue , if not you can attempt to clear the system cache in the Settings Menu or worst case download the latest update from Microsoft on your Computer , then follow the instructions & place it on a freshly formatted USB Memory Stick . Then place the USB Memory Stick in the 1st USB Port on the Xbox 360 & boot the console .
Apr 15, 2011 | Microsoft Xbox 360 Console
Whenever I turn it on, white dots start flying across the screen on my Xbox 360
It sounds like the the processor is over heating and its causing the system to shut down before it burned up the board. Basically your thermal paste between your processor and the heatsink is not doing its job. There could be a crack on it might have just degraded over time.
This can cause the system to freeze or see white dots on the screen. It needs to be repaired before more issues happen. Dont turn it on you might cause more damage
Thank you
May 11, 2010 | Microsoft Xbox 360 Console
Freezes on first screen
it sounds like your chip is fried same problem i had send it to microsoft!!
good luck
Jan 20, 2009 | Microsoft Xbox 360 Console
Games freezing...no red lights on ring
You can check out the articleatezinearticles.comhttp://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369formoreinformation on fixing freezing problem of your xbox 360
Jan 05, 2009 | Microsoft Xbox 360 Console
Freezing
Could be a due to a failed update or hardware failure.
Dec 15, 2008 | Microsoft Xbox 360 Console
XBOX 360 Elite - Will Not play games
Try to update the firmware of your xbox.
Jul 28, 2008 | Microsoft Xbox 360 Elite Console
Call of Duty 4 keeps freezing
It only freezes online during multiplayer a couple minutes into gameplay.
Jun 21, 2008 | Microsoft Xbox 360 Console
My xbox 360 keeps freezing!!
wrap your 360 in a towel (Completely Covered), turn on the system for about 10 minutes, turn it off, then back on again and and it should work.Although this fix only works fr about three hours it works over and over but the problem you have can also be fixed by replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your 360. But my second solution should only be used if the warranty is void
Apr 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
