Question about Whirlpool LER7646E Dryer
Whirlpool LER7646E dryer is not heating
The dryer spins and blower works but no heat checked no power going to element
  • Anonymous Jan 16, 2009
    My dryer spins and produces air but no HOT air...
  • flyingtarzan May 11, 2010
    ok so I assume you have a ohm meter?
  • Whirlpool Master
  • 8,220 Answers
Mounted on the element is 2 limits. If either is open their will be no heat. NOTE: both need to be replaced and they come in a kit:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2008
Whirlpool dryer ler 7620 kq8 Dryer not heating I replaced the heating element and it is still not heating. what do you think it is?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool LER7646E Dryer
Dryer has no heat
Ohm the heating element for continuity but the problem probably
is a small football looking fuse on the left bottom.
There is a thermal cutoff at the top of the element case with 2 wires
Hook these two wires together for a check or ohm it for continuity. Same with the fuse. The dryer should run. unless it is a more tech problem.Also check for 230 volt at the wall and at the service cord at the dryer. A dryer will run on 115 but it will not heat.
for more questions.
Leo Ponder
imufo2@sbcglobal.net
Jul 26, 2010 | Whirlpool LER7646E Dryer
Need to replace heating element
Hi ,
You need to open the back wall.
the heating element is on the bottom right side you will see a big metal unit on the right side the bottom part of it is the Heating element and 2 wire going into it.
2 screws connect it to the big metal unit.
take them out disconnect the wire and get a new one it run for :+- 50$
Jan 04, 2010 | Whirlpool LER7646E Dryer
For Dryer Model LER7646EQ1, dryer runs but no heat, It could be the heating element, the thermal fuse or other. Also the dryer has been running hot.I do not know how to remove the front panel
This sounds like a faulty thermal fuse or heating element. The fact that you said the dryer has been running hot could indicate that the heating element was making contact with the heater box or the high limit thermostat is faulty. Both the thermal fuse and heating element can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a faulty component. When necessary to replace a thermal fuse it is best to change the high limit thermostat as well. They will sometimes come as a set from a parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Whirlpool LER7646E Dryer
Dryer spins, air flows through vent but isn't hot
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Sep 15, 2009 | Whirlpool LER7646E Dryer
Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Jul 31, 2009 | Whirlpool LER5636P Electric Dryer
The Heating elment is not going on
Hello. You have one of two problems. The heating element is bad. You can test this by removing the wires on the element and testing for continuity. If there is no continuity, replace the element. If there is, look around the element for a small thermal cutoff and remove the wires from it. Test it for continuity. If there is none, replace the cutoff. If you provide me with the model number I can get you the part numbers you need.
Jul 15, 2009 | Whirlpool LER7646E Dryer
Whirlpool LER646EQ0 Heating element will not stop heating when door is opened.
Operating thermostat has failed 'ON' Needs to be replaced. Look at photo:645948c.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 06, 2009 | Whirlpool LER7646E Dryer
No heat on Whirlpool leq8000jq1. Is it just the heating element?
There are several things that could cause this problem, here are a few common things it could be, before doing any checks you should always make sure you disconnect your appliance from it's power source.
  1. bad heating element, you can check the heating element for continuity with an ohm meter.
  2. bad thermal fuse
  3. faulty power cord
  4. bad thermostat
  5. tripped breaker or blown fuse from house power supply, check to see if you have 240 volt supply to your appliance.
Mar 15, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
254 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
