Question about Canon S 330 InkJet Printer
Balck ink not working
When printing black will not print,color is OK
  • Anonymous Jun 30, 2008
    black ink is not printing
  • ivy domingo Jul 14, 2008
    blank ink did not function well i replace the new one original, model DCP-150C
  • 12 Answers
This is what worked (so far) with my DellBalck ink not working - 1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Posted on Feb 02, 2008
    Problem Solver:
  • 13 Answers
As if you followed above steps and still facing problem than try this also.
try cleaning the contacts, if there is alot of ink on them then it could cause this issue. use a qtip and isopropyl alchohol. clean the pen catrriage contacts (where the ink cartridge seats in printer) if that doent work then most probably something has failed within the printer.
buy before repairing you must ask the cost as new printer is not soo costly now a days.soo it is worth to buy a new printer install of high repairing cost.
And one more thing you can do is try another printer ink cartridge( Cheap Printer Cartridges ) and check if printer is working fine or not.
Also mention which model printer and Cheap Printer Ink Cartridges you are using
Posted on Jan 31, 2008
  • 22 Answers
#1.Have you tried changing the ink cartridge? #2.Be sure the sticker (usually yellow) on the top of the cartridge has been removed so that the cartridge has air supply then it can print. #3.Sometimes, during transportation, the cartridge may have been laying on one side, causing the colors to mix, or the print head to dry out. This does happen with both brand new AND remanufactured inks quite often. The first thing to do is try to print 6-10 pages, using all the colors. This may allow for the missing colors to "kick in". If this does not work, then try the following trick (which has an 85% success rate) 1. Take the cartridge out of the printer. 2. Place two paper towels on top of each other and fold them again so that you have a thick square piece. 3. Slightly dampen one side of the paper towel, keeping the opposite side dry. 4. Hold the cartridge with the print head facing down and "dab" it onto the wet portion of the paper towel, using SLIGHT force, for a second or two. 5. Dab the cartridge onto the dry portion of the paper towel. 6. Repeat steps 4-5 about five or six times, ending with step 5. 7. If you have a 3-color cartridge, you should see a line of cyan, magenta, and yellow on the paper towel. 8. Place the cartridge back in the printer and print a test page.
Posted on Mar 17, 2007
2 Suggested Answers
komguy
  • 2306 Answers
SOURCE: wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Posted on Dec 04, 2009
Wtf, Ink?
please replace balck cartridge with other or pump it with air from its in inserting hole.or clear ink head connector
Jul 28, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
I have run out of color ink want to print with black only
all you want to do is to remove the color cartridge then that's it you can now print in color balck
Jan 07, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I change the setting on my printer to color
give print .... select the printrt .... select preferance ...color tab ....here you can change the setting to print the documant in balck
this one you have to do when ever you will give the print......
Oct 07, 2009 | Compaq Inkjet IJ600 Printer
Printing color is ok but no black
printer is probably too old . buy a new one
or just print everything out in blue or sumtin other than black.
(thats what i do when my black ink is out)
Jun 30, 2009 | Brother MFC 420CN All-In-One InkJet...
machine needs to go into a cleaning process once you installed new cartridges to identify that there is a new one placed there.it will need 5 cleanings to do that.if you are using refillables or generic cart,then it wont properly mix up with the others causing that specific color not to print
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
brother mfc-5440 ~ same exact issue on not printing the black AFTER purchase new cartridge (again!) ~ i should have checked here first.... NO MORE BROTHER printers in our future & will tell all our friends, too....
Mar 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
My Canon printer wont print.
You could be facin one or both of these problem, Either the ink which u say is a refill is not good, note that they do expire, ur ink containers may be damaged or the ink sensors
Feb 22, 2008 | Office Equipment & Supplies
The printing head have some dryed black ink inside.
Look at Canon i550 section in this website. I have posted several answers on how to clean the print head.
Feb 09, 2008 | Canon BubbleJet i560 InkJet Printer
Canon S 330 InkJet Printer Logo
245 people viewed this question
Clive
Clive
old marine
old marine
