Question about Samsung ML 2152W Laser Printer
Printer reboots after first page
Several problems.
1. Printer resets itself after the first try to print. Once it is warm, seems to be better
2. The print is wavy, almost like italics, but not italics.
3. Wireless is very erratic, network cable a little less erratic and USB better. Meaning, on wireless, much of the time it loses the connection and even with the ethernet cable, seem like the connection goes away. I am now connected to the USB cable and it stays connected, but still has that reset problem. The wireless network has worked using the current setting for over a year, and I have checked them for changes and they are correctly set.
Printer has about 25000 pages on it.
5 Suggested Answers
SOURCE: Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Posted on Oct 26, 2008
SOURCE: network printer support how do I connect 2251N
http://uis.georgetown.edu/software/documentation/winxp/winxp.network.printer.html
http://www.stanford.edu/services/ess/pc/docs/xp_printer/index.html#anchorone
http://www.online-tech-tips.com/windows-xp/how-to-install-a-network-printer-on-your-home-or-office-network/
Setting Up a Network Printer
Preparation
In order to install a network printer, you must know your printer's Manufacturer, Model Name, and IP Address.
The Manufacturer and Model Name can be found on the printer case, an example is HP LaserJet 4000N. The IP Address can be found on a label attached to the printer. An example of the IP Address is 141.161.888.999. If your printer does not have a label indicating the IP Address, or you can't identify what model it is, please call your printer manufacturer.
1. Click on the Start button, then click Control Panel, then click Printers and Faxes, then click Add Printer.
2. A new Add Printer Wizard window opens. Click Next to start.
3. Select Local printer attached to this computer. Make sure Automatically detect and install my Plug and Play printer is NOT checked.
4. Then click Next to continue.
5. We will create a new port for your network printer. Select Create a new port.
6. Beside Type of Port, click on the down arrow, then click on Standard TCP/IP Port.
7. Click Next to continue.
8. A new Add Printer Port Wizard will open. Click Next to continue.
9. You must now type your printer's IP Address in the Printer Name or IP Address field.
10. The Port Name will automatically be filled when you enter the IP Address. Do not change the Port Name.
11. Click Next to continue.
12. IF YOU HAVE PROBLEMS, then you will see the screen on the right. This means that the IP Address for the printer is NOT available on the network. Select the Back button and make sure you entered the correct IP Address. Check to see that your network printer is powered on and displays a 'ready' status.
13. IF YOU DID NOT HAVE PROBLEMS, Windows XP will scan the network to find your printer's IP Address. This may take a few seconds. Select Finish to continue.
14. You must now select the printer's manufacturer and model. Windows XP will automatically select the detected manufacturer and printer driver. Normally, you will not have to change this selection.
15. OPTIONAL: If your printer is listed but you have more than one printer model to choose from, please select the model with PS, if available.
16. IF your network printer is NOT automatically detected, select the Windows Update button to find the proper software drivers.
Note: If your printer is not automatically recognized using Windows Update, please call your Help Desk.
17. You will be prompted to confirm the selected printer driver. Make sure Keep existing driver is selected, then click Next to continue.
18. You will be prompted to assign the printer a Name. You can use the default name, or add more info to indicate the printer location, such as My Office, Hallway, Foyer, Room 222, etc.
19. Select Yes if you want to use the printer as the default printer. Click Next to continue.
20. You will be prompted to share the network printer. Do NOT share the network printer.
21. Click Next to continue.
22. You will be prompted to print a test page. Select Yes, then click Next.
23. Check your network printer to make sure your page printed. Select Yes when prompted to confirm a successful test page.
24. Click on the Finish button to complete the Add Printer Wizard.
Congratulations! If your test page printed, you have successfully installed the network printer.
Note: If you had problems and did not get a test page, please call your printer manufacturer.
Posted on Mar 30, 2009
Semi-Driver
  • 434 Answers
SOURCE: I want to connect my SCX 4500w to a new network.
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Posted on Mar 07, 2010
SOURCE: printing wavy letters instead of straight
we have similar problem. my printer is canon mp 145. straight lines become wavy and some letters are italics when printed out. it was corrected when i used print head alignment but that was true when printing from my computer and not when using the copier. when using the copier lines still comes out wavy and i cannot correct it until now. please post when you solve your problem. i hope it will help you and i hope you can help me
Posted on May 16, 2010
Only prints one page
Can you delete your printer from your pc and reload it? mine hangs up once in a while too. Just weird gremlins as sometimes it's perfect.
Jun 27, 2014 | Dell V313w AllInOne InkJet Printer
Prints on partial page of an 81/2 x 11 photo paper. Prints OK letters fm word.
Instead of using the Letter or factory 8 1/2 x 11 page set up, create a custom page size for 8 1/2x11 and use that in your app for the page set up. Double check your page orientation and the size of the photo you are printing. It sounds like it may be trying to tile the photo because it's too large for the page size.
Sep 14, 2017 | HP Photosmart C6280 Printer
My printer is printing but i cant scan my documents - no compatible printer installed
Make sure the Lexmark OCR scan software (used to scan documents, convert into PDF file or create multiple pages into 1 file). The software is available on the installation disc that came with the printer.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your problem, your rating will be greatly appreciated. Thanks.
Oct 20, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Page is not printing completely
However, if you're trying print but the print status screen only goes partial, try to follow the steps below to fix the issue:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh. Try print again to verify that the problem is fixed.
Oct 13, 2011 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 4580 all in one prints data not on page to print
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/pOdfTQ. Select your operating system, download and execute the file.
Oct 07, 2011 | Lexmark X8350 All-In-One InkJet Printer
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
Lexmark X4650 prints fine & used to scan to computer, now when press scan>scan to computer>downloading application list & seems to freeze.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X4650 InkJet Printer
I got it hook up to my laptop and i wanted to print out 1 or 2 pictures. And it wont print.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 19, 2011 | Lexmark X3550 All-In-One Printer
Printer wont print
Try the simple solution first. Uninstall the printer, reboot and reinstall. See if you can print a test page from the printer itself to make sure it still works period. If you can't print the self test page (which is the printer talking to itself) the computer won't be any better.
Dec 03, 2008 | Canon BJC-85 InkJet Printer
Strange printing issue.., need assistance ASAP!!
when it receives the test page and doesn't react
1-does it go back to ready?
2-do you have to physically hit ther green button?
If everyone else can print ok then it can't be the printer !!!!
and you can ping it with no problem,
1-are you sure it is set correctly go to the properties setting under device settings is everything ok.
2-I suspect his driver is bad, try to reinstall.\
3-you can try to do a cold reset, although I don't think it will do anything since it's mainly one user problem.
Aug 07, 2008 | HP Color LaserJet 2600n Printer
Samsung ML 2152W Laser Printer Logo
55 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
