Question about ASUS P5RD1-VM Motherboard
Computer wont boot after memory upgrade
I have an HP Pavillion a805n with Goldfish2 GB8L (Asus PTGD1-LA) motherboard. It originally had 512 Meg (two 256 DDR SDRAM) and I purchased two 512 Meg DDR PC3200. I unplugged computer and all external connectors, unplugged cord between motherboard and power supply, removed the old chips, installed the new chips in the old slots, and installed the old chips in the available slots. Computer does not boot. Green power LED on power supply blinks and I hear a "clicking" sound. Removed all chips, reinstalled the old chips, same result. No combination of chips results in successful boot. If I unplug the motherboard, the green power LED on power supply is on solid, no sounds. Have I fried my motherboard, and if so, how?
Any help would be greatly appreciated. I don't want to buy another motherboard and fry that one, too...
Mike
  • mbowyer Dec 16, 2008
    Thank you for the reply... the only cable I disconnected inside the computer was the power supply cable to the motherboard. The board has two pairs of memory slots: two blue and two black, with one of each color in each pair. The original memory was in the two blue slots. I put the two 512 cards in the blue slots, and the two 256 cards in the black slots, hoping to get a 1.5 gig. Is it possible I cracked the motherboard disconnecting the power supply cable? It was difficult to remove it...
When working on computers you have to be carefull to ground your self before touching the inside of them. when installing memory you dont need to unpluge everythinf just the main power cord on the back of it.the blinking green light means you have something no pluged in right,double check everything you unpluged make sure it back in the right areas.on memory the slots are mark 1,2,3,4
make sure if the memory is diffrent in speeds the lagger ons go first.the first to slots normally have to be the same speed and size ram.if that does not work let me know i can look into it for you.
Posted on Dec 15, 2008
Looking for motherboard driver asus ptgd-la
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 14, 2011 | ASUS PTGD1-LA Motherboard
What is the Maximum graphics memory supported on the Asus PTGD1-LA Motherboard, Or specifically on The Hp pavilion a767c desktop? Right now my a767c desktop has an Ati-radeon x300 SE 128mb ddr 64-bit...
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today. You didn't specify your operating system, which is a critical component. With a 32 bit operating system the total addressable theoretical memory limit is 4 MB. This includes system ram AND video ram. You should be fine with the 256MB card as it is pretty small. So, if you have a 32 bit system, anything over about 3.2 MB total is a waste.
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today.
Jan 20, 2011 | ASUS PTGD1-LA Motherboard
I have the ASUS PTGD1-LA Motherboard, anyways, i recently took out all the components inclucing the motherboard, to look at the bottom side looking for the id number..Anyways, I put everything back...
Hi there , THis sounds like a CPU issue...Make sure you correctly put the CPU fan , and heatsink back on .... otherwise your CPU will overheat and cause your PC to turn off , so that it wont damage your CPU.Try making sure those are correct.
Thanks
May 22, 2010 | ASUS PTGD1-LA Motherboard
Anyone know why an ASUS PTGD1-LA motherboard will only take memory in slots A1 and A1 or A1 and B1 but not anything in B with both in A filled? Brand new memory.
HI,
The board has specific requirements for memory. Here's the Memory Configurations :
  • You may install 256 MB. 512 MB and 1 GB unbuffered non-ECC DRR DIMMs into the DIMM sockets using the memory configurations in this section.
• Installing DDR DIMM. Other than the recommended configurations may cause memory sizing or system boot failure.
• In dual-channel configurations, install only Identical (the same type and size) DDR DIMM pairs for each channel.
• Always install DIMMs with the same CAS Latency. For optimum compatibility , It Is recommended that you obtain memory modules from the same vendor
• Double-sided x 16 modules are not supported on this motherboard.
• Due to chipset resource allocation, the system may detect less than 4 GB system memory when you installed four 1 GB memory modules.
For dual-channel configuration you may:
install identical DIMMs in all four sockets
• install identical DIMM pair in DIMM_A1 and DlMM_B1 (blue sockets) and identical DIMM pair in DIMM_A2 and DIMM_B2 (black sockets)
• install same size DIMMs in DIMM_A1 and DIMM_B1 (blue sockets) and another same size pair in DIMM_A2 aid DIMM_B2 (black sockets)
Hopefully this will help understand how to install the new memory.
Thanks Mark
Mar 19, 2010 | ASUS PTGD1-LA Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Memory upgrade problems
Same here, except that I haven't even been able to get 512MB x 4 to work. Also upgraded BIOS. Did it run OK on 1GB x 2? (Mine does.)
Jan 20, 2010 | ASUS PTGD1-LA Motherboard
How should I upgrade my BIOS pls
The first uestion to ask yourself is "Do I need to upgrade my BIOS?"
If you are not conversant with doing so then you could rendr your PC irrepairable.
The BIOS is the heart of the motherboard and has nothing to do with system issues and should not be taken on by novice computer users.
If everything is running OK don't try and fix it.If not state the problem, it will probablely have nothing to o with the BIOS
Oct 03, 2009 | ASUS PTGD1-LA Motherboard
Gigabyte GA-60X Memory upgrade.
Hey syconus, Matt here- It will unfortuatly still only take the 512mb because it is not compatible with the new memory. Sorry:|.
Dec 31, 2008 | Gigabyte GA-6OX Motherboard
ASUS P5RD1-VM Motherboard Logo
584 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
