Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
DOOR GROMMETS ON BOTTOM OF REFRIGERATOR DOOR IS BROKEN
The Model # ED5GHEXNL02
Serial # ST1145667 Year Mfg 2006
Purchased at Home Depot in Surprise, AZ. in 2007
I can't find the smodel # on the web site to order the new grommet or washer for the door on the fridge side. Please let me know how to get this item, the door swings offset as you open and close it because the washer/grommet is split.
    Top Expert:
  • Whirlpool Master
  • 52,162 Answers
Get it from the service agent spares
take the old one as a sample as the bush could be generic and fits most doors on many fridge makes and go to all of the manufacturer service agents for a spare one
Posted on Sep 24, 2017
SOURCE: Refrigerator door stays open.
Sears came out and repaired my door with this same problem. It was a pretty easy fix. There is a small black part that the door rests on. It just was worn out. The repairman simply unscrewed the door from the top of the refrigerator. He lift the door off. The door normally rest on a black round circular plastic part about 1 in in diameter. It has a small plastic piece sticking up about 1/2 inch that the door rests on. This piece was worn on bottom. I have the Sears invoice and I bought a replacement bin for the door and I don't know which item is for the black plastic piece. Here are both part numbers so call Sears and order the correct part
CAM-DOOR 46 106 4318165 1 or $14.83
SUB TRIM-DOO 46 106 2156022K 1 $12.48
It took the Sear's guy about 10 minutes to repair. So save yourself $200 and do it yourself.
There is a picture of the part in the Whirlpool Manual, under Door Removal, look at the bottom hinge.
Email me if you need another picture.
lcbeaty2004@yahoo.com
Posted on Nov 27, 2008
sdmc73
  • 121 Answers
SOURCE: French door on right keeps swinging open
yhe leveling of the unit will help
Posted on Nov 29, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
SOURCE: wheel wobble on pram when walking. spac
sent wheel to bebecar fo repair
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: 92 FORD T-BIRD 5.0L SPORT TRANSMISSION problem
3RD GEAR IS THE DIRECT CLUTCHES . WHEN THE GROMMET BROKE YOU LOST LINE PRESSURE IN THE TRANSMISSION RESULTING IN BURNING THE CLUTCHES .THE ONLY FIX IS TO REBUILD OR REPLACE TRANNY.BAD DESIGN BY FORD .YOU CAN FIND A BRONZE ONE AFTERMARKET
Posted on May 07, 2009
Stainless steel hose leaking on pull down kitchen faucet purchased Nov 2014- is putting out a fine mist at the bottom of hose loop - do I have to get parts from Home Depot where purchased?
Ordinarily you get parts from the mfg of unit. However Home depot may have available a universal repair part for your unit. No harm in checking.
Sep 04, 2017 | Plumbing
Door will not remain closed
Check to see if the shelves are not hitting the door shelves. the crisper drawers are in properly and there is not something too large in the door shelves. This is the usually reason for the doors not to stay closed. the other reason could be a bad door gasket.
Apr 21, 2015 | Refrigerators
On 9-1-14 I purchased a Maygag refrigeration model Mitxegmyw01 from Home Depot in Decatur, GA 30033. The refrigerator light is very dim and I can hardly see the food below the top shelf. I am very d
Sorry to hear of the problem with your fridge. Seeing you just purchased it, you have a one year warranty on most appliances. I suggest that you call Home Depot and tell them about your problem, and if they cannot fix it, tell them you want it replaced as you are not happy with the way it is working. Good luck, let me know how it goes with them..
Sep 27, 2014 | Refrigerators
How to change light bulb in Kenmore refrigerator serial no. 4A31214613 ?
Open freezer and reach to the back of the plastic cover over the light. You'll feel a gap in the back center of the cover. Gently pull forward and the cover will drop down and pull to the back to fully remove it. Once you've removed the cover you can unscrew the bulb, which you can use to make sure you purchase one like it and most hardware stores, such as Ace or Home Depot. Reverse the removal instructions to install light and cover. Light should turn on once you've screwed it in.
Jul 22, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a refrigerator model #GD5PHAXMS10 icemaker that stopped working about two and a half weeks ago. At that time the water the water works dispenser worked like normal. Today the water dispenser...
The first thing to do if you already haven't is replace the filter,it's in the grill/kickplate below the freezer door. If you have relpaced filter,need to pull refrig from wall and check that their is good water pressure from house plumbing,if it is good the water valve the sends water to icemaker&door dispenser when water is called for is going to be the problem.The part # for that valve is 4389177 it could be purchased at your local appliance parts store on oline at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
The filter BUT NOT the water valve could be purchased locally at Sears,Lowe's or Home Depot
I hope this helps you to diagnose your icemaker/dispenser
Gene
Aug 07, 2011 | Refrigerators
RE: 42'' zero turn Toro with Kohler 19 hp. Ever since I bought it new, it has used oil, I am very dissatisfied with it. Model 74360 Serial #270000001. The starter relay doesn't work correctly. It will not...
Toro is a great brand, but the Home depot models are for home use. IF it won't start correctly you should troubleshoot the problem as this is a built in safey system for your benefit. There is a switch on both parking breaks, A switch to detect you sitting in the seat. The PTO must be disengaged. Check each of these. If you have your manual you can view the schematic diagram, and test each switch. If not, you can download a manual from Toro web site. According to your model and serial number your deck would only have two blades. They also have what they call "blade stiffeners" . Your results from buying power equipment from a big box store is typical. If you need service, pay a little more, and buy from your local power equipment distributor.
Jul 12, 2010 | Toro Garden
Lg lrfd23850 water is getting into the freezer
Check the drain in the bottom of the unit in the back to see if it is frozen. It is aluminum with the drain in the center. Remove the cover on the back and check the drain tube.
Jan 22, 2010 | Refrigerators
Hinge Broken and Internal Locking Mechinism Falling Apart
higes have nubers on them as to which panels they got to if they have rollers if they dont have rollers they are # 1 hinges can be purchased from most any overhead door com if commercial get the heavy duty if residential lowes or home depot usually carry up to 1-4 # hinges hinges can be replaced by consumer without taking tension off except for bottom cable connector for this call a garrage door rechnician to replace hinges lower door fully and uncrew hinge and replace be sure to lubricate roller shaft.
Jan 09, 2009 | Sentry Fireproof Safe
Amana fridge door on wrong side
Generally, doors can be swapped side to side.  Look for some kind of plate where the hinges would be on the other side of the box from where you've got the door mounted now.  It may be covered with a plastic piece.  If you find it, you're in business.  A small socket set is all it usually takes.  Get help holding the door in position as you do the work.  Doors are heavy.
Nov 12, 2008 | Amana ARB2257CSR Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
