Question about Insignia IS-LCDTV32 32 in. Television
TV won't turn on
I purchased the Insignia TV 32 in. during the fall of 2005 (manufactured in June 2005). It has been working fairly well until March 2007 when I started having problem turning it on. At first, 'the unplug then wait and plug again trick' worked. Thereafter, TV remains as described by other customers: A blue light will quickly follow the red light then will disappear. Best Buy says: sorry we can't help, you did not purchase the warranty. The manufacturer warranty only lasts a year (past due). What should I do?
Replace the power box inside the tv. you can get the parts online thru best buy parts.com
Posted on Apr 27, 2008
    President:
  • 3,130 Answers
And then about 500 for labor
Posted on Mar 23, 2007
If you get a service man to come out and look at the tv there are three capacitors at the top of the power supply that look like they are about to pop replace and the tv will wotk fine. they cost about two dollars each
I'll buy your broken unit for $100 plus shipping if you'd like....I got a broken unit I'd like to try to fix. Let me know, cheT post here if so and I'll give you my email address
Posted on Jul 12, 2007
SOURCE:
My washing machine has stopped washing in every cycle, it keeps saying 'test' on the lcd display panel. When I do turn it on to do the 'test' it just spins for a while then stops and...
Hi Justine from retired Englishman in SW France,
Here are the instructions to clear the 'test' depending on the date code (possibly on the manufacturers panel at the back):-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to norma
l
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 04, 2011 | Hotpoint Washing Machines
Everytime i put my washing on it goes onto test mode. I reset it so it is back to the on screen and then evertime i press a cycle it goes back onto test mode. Ho9w can i get it out of test mode and back to...
You will have to look at the manufacturer's plate, probably on the back of the machine to find the appropriate date then-
Date code 39, March 2005
Date code 39, March 2005 to date code 42, June 2005
Press the cancel button and the machine should return to normal
Date code 43, July 2005 onwards
Good luck,
John C
Apr 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
How do you get rid of Test that appears on the screen in red
It depends upon the date of manufacture for Hotpoint (Indesit) washers. The date should be on the panel probably at the back in the most handy position, sorry!
Hopefully one of these should clear it ;-0)
Good luck,
John C
Mar 31, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Machine keeps showing test when start pressed, how do i clear this
Sorry but it depends on when the washer was manufactured. Here are the 3 alternatives- dates should be on the panel, probably at the back where it is difficult to get at ;-0(
One of these should sort you out ;-0)
Good luck, John C
Mar 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
Switch on it shows "test" and cannot programme
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
John C
Mar 22, 2011 | Hotpoint Aquarius WD640 Front Load...
I have the test displayed and it dosent matter
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and test appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Feb 24, 2010 | Hotpoint Ultima WF860 Front Load Washer
Insignia 26 inch TV/DVD Combo produces strange odor when on.
You should never have an acrid or burning smell coming from electronics. I'd return the unit, if that is still an option, as it is about to fail.
Feb 13, 2010 | Insignia IS-LCDTV32 32 in. Television
Last year I went to my company's christmas party and in a random drawing I won a 32 inch Insignia lcd tv. I've only had it for a month and for some reason it when i'm playing a video game or watching tv it...
1. You will need to check the units instruction manual.
This sounds like the LCD TV is in the "timer" mode that is the tv is set for 120, 90, 30 minutes and then turns itself off.
2. It also maybe a circuit built into the TV to protect the electronic components and will shut down the unit when it senses a heat or voltage change ( this can be a manufacturing defect) call the manufacturer and see if this is a recall. Some time the manufacturer will replace the unit even if it is a gift from the company you work for.
The unit has already been purchased and has full warranty status.
Hope this helps.
Jan 29, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Indesit1200 front loader not filling and flashing error code deno can anyone help
hi try these
To Activate
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)
To Deactivate
d OFF appears.
To Activate
To Deactivate
To Activate
To Deactivate
Aug 22, 2008 | Indesit Washing Machines
Hotpoint wf865
press on off button till test comes up then press on off and start cancel button together for a few seconds
Jun 26, 2008 | Hotpoint Ultima WF865 Front Load Washer
Insignia IS-LCDTV32 32 in. Television Logo
184 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
