I am driving down the road and the icon for a door opened comes. All the door are secured. Secondly when I lock the escape with my key lock the escape alarm goes off and the only it goes off is with the keylock. But I can't lock the escape cause the alarm goes off automatic and the lights are flashing. Help
SOURCE: 2002 taurus passenger door lock
Mine did this. I went around to each door and sprayed a liberal amount of WD-40 in the latch, then open and closed each door about five times. It hasn't done it since. I think the switch inside was not moving freely.
SOURCE: door lock staying locked so door cant clamp on to the striker
Hello and welcome to FIXYA, it sounds like you have two problems, first the door ajar switches in your truck are sticking, and causing the ajar light to remain on, and second the door lock actuator is shorted and getting stuck in the lock position. To repair the switches, obtain a can of brake cleaner and spray the door latch of each door for about 3 to 5 seconds, then open and close the door 10 times to work the cleaner into the switches. To fix the lock problem, you must first pull up on the knob in the door panel to unlock it. Then remove the door panel, and replace the door lock actuator.
SOURCE: 2005 Ford Escape - Door Open Indication Light & Horn Alarm Sounds
This is probably caused by:
a loose door switch, or
a loose connection to a door switch, or
a defective (dirty / corroded) door switch.
There is a false signal being sent that a door is open / ajar.
SOURCE: door ajar light comes on
The door lock relay or one of the door sensors/ switches is defective.
SOURCE: Driver side door is frozen
Give the locking "jaws" a good dose of WD-40 and start with a pair of pliers ans working the door handle get the "jaws" moving and work it a lot while keep dousing it with the lubricant. Worst case scenario would be that the spring that opens the jaws is broken and will need replaced. Please rate this answer, thanks.
