Question about Desa International Reddy Heater RH10PT 10,000 BTU Outdoorsman Vent-Free Heater w/TSTAT/hose/regulator
Reddy Heater Outdoorsman keeps shutting off
The piolet elight comes on but you cant turn the heat fast very low, as it will just shut down. once you turn it past low the flame will surge a little for a 1/2 second and then return to what it was at low. 10 to 20 secs. later it will shut off.
its a
Reddy Heater Outdoorsman 10,000 BTU Propane Vent-Free Heater #RH10PT
5 Suggested Answers
SOURCE: troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Posted on Jan 18, 2009
tbugger
  • 232 Answers
SOURCE: Reddy Heater R40 starts , then within a few
The R40 has an on board computer with a photocell that views the flame color. If the photocell does not like the color of the flame, then the heater shuts down....within 5 secs.
Your problem could be:
  1. the air pump pressure incorrect..
  2. defective electronics.
  3. restricted fuel supply.
  4. air leak in air line or fuel line
You must troubleshoot each of the above- starting with setting the pump pressure.
Tips http://www.reddyparts.com/HSI_tips.htm
Posted on Nov 10, 2009
SOURCE: My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Posted on Dec 04, 2009
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
'on how to light piolet on 18000 btu big buddy heater
You should be able to light a pilot with a lighter or match if the built-in igniter won't do it.
Make sure you set the ON/PILOT/OFF button to the PILOT setting, push in on the button while lighting the pilot light (flame), and keep holding the button down for about 20-30 seconds. Then the pilot flame should stay lit.
Apr 14, 2018 | Heating & Cooling
The piolet light will not light. If I turn the
You may have a plugged orifice in the pilot tube assy. If you have any way of getting to the orifice with compressed air, and blow back, it may dislodge it, if it is plugged. If possible, carefully remove pilot tube at valve end first, so that if it is debris in there, it blows clean of the tube, so it won't clog again. Otherwise you'll have to remove complete assy. Another thing to try as well, is to shut valve off, loosen fitting at valve for pilot tube, AND MAKING SURE NO FLAME OR SPARK ANYWHERE IN THE AREA, take a spray bottle with dish soap and water mixed (bubble tester) and then spray at pilot fitting when it is loose, and push pilot, to see if any bubbles appear, indicating gas flow. If no flow there, then I'd get a new gas valve.
Jan 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
Oct 28, 2009 | Heating & Cooling
I have DCS FSF-40N fryer. the piolet doesn't stay on when I release my finger it goes off I tried to change the gas valve from different brand and I only replaced small part where the electrical wire is...
You must first check to see if your pilot flame is good. If it is too weak, or not impinging properly on the thermopile, it will not stay lit. If the pilot flame is ok, the problem could be that the thermopile is weak. using a millivolt meter, test the voltage across the thermopile while the pilot is lit (you may need someone to hold the button down while you do this). You will also need to disconnect the thermopile's leads from the control while you do this. You should get about 750 millivolts across the thermopile while the flame is on it (let it heat for a while to stabilize). If your reading is too low, your thermopile may be shot and needs to be replaced. That is of course only if your flame is proper. That voltage is needed (or close) to keep the magnet open so it will stay lit when you let the button go.
Sep 04, 2009 | DCS FSF-40 Deep Fryer
Flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
PILOT LIGHT WILL NOT LIGHT
the thermocouple not only keeps the pilot on but lets the gas valve know its okay to open on a call for heat, remove your thermocouple and clean it with a fine grit sandpaper and if this doesn't work replace it all together.
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
How flem sensor works in furness
After you hearthe click from the ignitor your piolet will light. the flame sensor (mounted next to the piolet (tip in the flame) ) will sence the heat from the piolet sending a milivolt siginal back to the ignation board. once the board knows there is a piolet and the system is safe the main valve will open igniting the burner trays.
Mar 16, 2009 | Goodman GMS90703BXA Heater
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
When heater fails to start
if the flue is warm that would indicate that the flames lit for a short while. furnaces sometimes have limit switches that shut down the gas if the heat exchanger gets too hot. I would verify you have clean filters. and all registars open fully.
If the flames are not lighting verify gas valve is recieving the 24vlts. to open.
Also check ignition system it will be a piolet light or hot surface ignitor. you should be able to see both without much trouble. hs ignitor should get bright cherry red.
Sep 24, 2008 | Heating & Cooling
Heating & Cooling Logo
149 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Steve Allison
Steve Allison
Gil Shultz
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
