Question about Nokia 7360 Cellular Phone
Nokia 7360 keypad problem
Keys 4,5,6 has malfunctioned
My key pad has a problem pls help me
Posted on Feb 01, 2009
  • nilo88tagapa Feb 01, 2009
    pls help me to solve my problem my 7360 have a problem my keypad 1,2,3 is doent work
What os code 12
The FI light on our Yamaha is much like the check engine light on your car. If it comes on it is real easy to check the code, and for the bike to tell you what is up. Just ground the diagnostic wire and it will start reading them out. Mine just had one code, but it will read out as many as you have. Then you can know what to address to potentially fix issues with the bike. There are more than this, but below are some basic codes to work with. Service Codes FI Indicator Light (LED) Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction
31 Vehicle-down sensor malfunction, wiring open or short
32 Sub throttle sensor malfunction, wiring open or short
34 Exhaust butterfly valve sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
51 Stick (Ignition) coil #1 malfunction, wiring open or short
52 Stick (Ignition) coil #2 malfunction, wiring open or short
53 Stick (Ignition) coil #3 malfunction, wiring open or short
54 Stick (Ignition) coil #4 malfunction, wiring open or short
62 Sub throttle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
May 01, 2016 | 2005 Yamaha FZ6 Fazer
C0550
The C0550 means that "ECU Malfunction internal write/ checksum malfunction", luck for you!
T300+ key programmer
Jul 19, 2012 | 2004 GMC Envoy
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Feb 01, 2011 | kawasaki ZX-6R Motorcycles
Pls my sharp AR-206 copier is malfunctioning.It doesn't boot at all and all it keeps displaying is H and 4. Kindly help me on how to fix this problem.
Perform the following procedure to solve this problme:-
press "# key"___"Interubt key"__" 0 key"___"Iterubt key"___"14"___"print"
Jan 10, 2011 | Sharp AR-207 Copier
2005 crysler sebring 4 cyl no start p 0340 code changed camshaft position sensor still no start. key engaged engin turn over, fuel present, no start, occasionally get a small backfire. HELP!!!
Try substatutting the ignition module with a known goog one.Also have the camshaft CIRCUIT checked at the camshsft sensor plug in, for propper voltage.The code P0340 indicates a circuit malfunction not a sensor malfunction. Good luck.
Dec 07, 2010 | 2005 Chrysler Sebring Conv
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
Central locking on mk 5 golf works fine with key in lock and from inside car using switch but only unlocks drivers side using key fob. any answers?
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Polo: Press key unlock button for approximately 1 second. Golf/Bora: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
How - Polo
Keys can only be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed.
How - Golf/Bora
98MY
How - Golf/Bora 99MY
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Keys can also be programmed using diagnostic equipment.
Mar 07, 2010 | 2001 Volkswagen Golf
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
How
Jan 25, 2010 | 2004 Honda Accord
Error c12c0 in minolta di 550
C12CX (X is any value) deals with the hard drive
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Oct 28, 2008 | Konica Minolta DiALTA Di200 Copier
Error c12co in minolta di550
Nokia 7360 Cellular Phone Logo
187 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
