Question about Kenmore 659 Electric Dryer
Kenmore electric dryer vibrates loudly
Model 417-80052990 dryer vibrates very loudly when drum is spinning. Does this unit have drum wheels under drum or could it be the bearing shaft and ball assembly?
Thanks
  • mlmaschmeyer Dec 15, 2008
    Took drum out and there are no roller wheels. The spindle in the rear of the drum sits in the bearing support cup. The grease was dried up causing vibration. Works smooth now but I still can't believe this was the problem.
    Thanks,
  • Anonymous Mar 23, 2014
    somthnig went into the back of dryer and now vibrates
  • 71 Answers
Yes the kenmore uses the roller wheels . dr fixit in the service providers has them. Any way I can help otherwise?
Posted on Dec 15, 2008
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
Kenmore 90 series makes a loud noise during spinning and it looks like the basket is loose
On most Kenmore or whirlpool dryers, you have two wheels that have rubber around them. They look like wheels off of rollerblade skates. They simply bolt on to the back, but you have to usually put a large piece of wood to act as a fulcrum as you support the weight of the drum and change out the two wheels. Check with searspartsdirect.com for the parts prior to taking the dryer apart. I had a machine that sounded like tennis shoes were rolling around the drum and fixed the issue by simply replacing these two wheels.
Good Luck
Jul 23, 2014 | Kenmore Washing Machines
Kenmore dryer noise
It will be either a worn bearing or belt tensioner, the only way to diagnose further is to dismantle the dryer and check each bearing individually.
Mar 06, 2012 | Kenmore Dryers
How stop front loading electric dryer vibration while drum is rotating clothes.
110 means you have a whirlpool dryer. If the filter is on top then I would say you have a bad glide, if the filter is in the door you have a bad wheel, very rare. At any rate you need to open it up and inspect it.
Videos and more on kenmore dryers
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Vibration
I had a technician out who said it is the nylon wheels - when it's cold outside the dryer drum is cold - once you start the drryer ( I know it's very loud) the wheels warm up and quiet down - you can order new wheels I think - different material.
May 13, 2008 | LG DLE2514 Electric Dryer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Kenmore 659 Electric Dryer Logo
397 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
