Question about Gemmy Rocky Balboa Big Head Animated Talking Doll Featuring Sylvester Stalone
Gemmy Santa Bear mouth does not move
Gemmy products seem to have the mouth go out first. I have several, Bing Crosby does not move his mouth any more, The Christmas Santa Bear. Is there a way to fix them?
  • Anonymous Mar 30, 2014
    Mouth won't move
    Problem Solver:
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Posted on Jan 02, 2009
The repair listed is just the start. You can, with a lot of careful work, remove the bottom of the mouth, but your work has just started. You will then have to remove the rod that holds the mouth rod to the mouth slide lever "spine". It has a small spring at the top and I found it easier to disconnect the spring prior to repairing the unit. It is glued in quite well so I suggest a Dremel tool to cut the sides off which you will enable you to remove the rod. Then you can remove the head from the spine without difficulty. Now you will see that the problem is as stated, the string that pulls the mouth open has separated from the motor shaft. The cause of this problem is that the grease that the mouth slide lever rides on has migrated to the string, and then, softened the glue, which allows the string to separate from the motor shaft. Now, clean the shaft and replace the string. The original string is nylon. You should use similar material, NOT cotton string or a rubber band. You can't use the old string as it is soaked with lubricant. Use a good super glue to bond the new string to the motor shaft. Next, test the unit to make sure that the mouth slide lever operates properly. Reassembly of the unit would be: remount the head to the neck, then reattach the mouth rod to the mouth and then reattach the mouth and rod to the mouth slide lever.
Posted on Aug 29, 2009
Santa moves and mouth moves but no sound.
Hi there my Santa sound is coming on real low then goes off
Nov 18, 2013 | Gemmy Life-Sized Animated Santa
My gemmy dancing santa bear wont move any more i need help
I is very good that the http:www.molitop.com goods,You can take a look at Lady Gaga Halloween Costume Kit, you should be satisfied.
Oct 15, 2012 | Gemmy Life-Sized Animated Santa
Dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
Sep 28, 2012 | Gemmy Bing Crosby Big Head Doll
Mouth does not move
Motor operating mouth assembly is bad. The process to remove it is tedious and the motor is specific to the design. This was a common problem with all of the motors in this series. Especially the one operating the mouth. The input pulsing necessary for the mouth to move, was to abusive to the motor, and subsequently shortened its life.
Dec 18, 2011 | Gemmy Bing Crosby Big Head Doll
MOUTH IS NO LONGER MOVING
probably it needs some serious spanking :)
Jan 25, 2011 | Gemmy Bing Crosby Big Head Doll
I have a Bing Crosby Gemmy Pop Culture Series animated "doll" that sings. He is AMAZING and a family treasure. I don't know why but his mouth stopped moving this Christmas and I am just...
I have had my Bing have the same thing happen. I did repaired it my self . There is a string that works his mouth attached to the motor.You need to remove the head and you are able to repair it.I could fix it for you.john
Jan 05, 2011 | Gemmy Toys
I need instructions on how to pop up my gemmy animated singing santa
It is suposed to pop up once you press on its shoulders. Once you press them both down you will hear two clicks and release and it will pop up. Mine was jammed and when I pressed it down on the shoulders only one side would click, the other side would not click so Santa did not pop up to full size.
It was jammed on the white area of the stocking, the material got tucked inside the click mechinism prevent it from making proper contact. To fix it I simply pulled the white stocking material up (as if you are going to roll the pant leg up) and then when I pushed the shoulders down after that it opened up just like it should!
Dec 16, 2009 | Gemmy Bing Crosby Big Head Doll
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
Gemmy Rocky Balboa Big Head Animated Talking Doll Featuring Sylvester Stalone Logo
1,504 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
