Question about GE Dishwashers
Water in tub of dishwasher
There is approx 1 inch of water standing in the bottom of the dishwasher after cycle complete. otherwise works well. checked the air gap it is clear. the dishwasher has its own drain separate from the garbage disp or sink. model GSD5400G00WW
markevans
  • 148 Answers
SOURCE: my dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
Posted on Dec 21, 2007
Loringh
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
  • 81 Answers
SOURCE: dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Posted on Apr 24, 2009
ginko
  • 19396 Answers
SOURCE: Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
Posted on May 21, 2009
garing
  • 998 Answers
SOURCE: Wont final drain, Have cleaned all drain openings,
instal pump kit
thumbs up
Posted on Aug 17, 2009
Leaking from bottom middle and right side of door
The center spray arm may not be turning straight and level, causing water to spray over the top of the splash shield. The shield needs to be adjusted to block water as it is sprayed from the center arm.
1. Remove the bottom door seal and reinstall, making sure there is not less than 3/8 inch of seal showing below bottom of internal door panel before closing the door.
2. Check tub seal, at the bottom the tub, seal makes a right angle and points to front of tub. In tub bottom there is a block molded in the tub, the tub seal is to fill this block but not extend over.
3. Select the shortest wash cycle or just use a rinse and hold cycle if available. Run the cycle, making sure the water spray changes from bottom to center not less than twice before making any adjustments.
4. If splash over is found, work only one side at a time. Remove black door seal enough to raise the splash shield up off the bottom of the tub not more than 1/8 inch and reinstall door seal properly. Retry and check for leaks.
5. If leak persists, remove door seal again. This time raise shield an additional 1/16 of an inch, then reinstall tub seal. After the first adjustment of 1/8 inch, any other adjustments will be no more than 1/16 inch at a time.
6. After splash over is stopped on one side go to the opposite side if needed.
May 11, 2010 | Frigidaire PLD2855RFC Dishwasher
Water will not drain from bottom of dishwasher.
few things
(1)make sure drain line has a high loop going to the drain not just a strait shot and its clear of ubstruction.
(2)there is a screen at the bottom of the tub unscrew it and check for a blockage.
(3)check the pump
If you require a part i recommend appliance parts solutions they have the cheepest parts i have found.
good luck!
Jan 21, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
The water in our dishwasher does not completely drain out after the cycle finishes. There is 1 1/2 inches of water standing in the bottom of the dishwasher.
check the drain filter,clean the filter.make sure the line going to your gabage dissosal is clear.if you do not hear water going through garbage unit than you have a blockage or a bad impeller fan or a bad pump.
Nov 16, 2009 | Air Purifiers
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
107 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
