Question about Vizio L37 Television
I have no power to my television. The vizio power logo is not even yellow.....unplugged and plugged back in and nothing....please help
  • 1 more comment
  • dmmckinney05 Dec 15, 2008
    I have contacted tech support. My tv is till under warranty (8 months old) and a repair tech will be coming out to the house to fix it within 10 business days! lol with the holidays right around the corner, I am sure it will be well after the 1st before anyone gets out here!
  • Sandra Nov 03, 2012
    Please tell me what was wrong with your tv I have the exact same thing only my warranty expired 2 months ago. What did the part cost or did they put that on the invoice since yours was still under warranty? Thx
  • Anonymous Mar 31, 2014
    TV is plugged in, but there is no yellow logo light at bottom of TV. Obviously, there is no power getting to the TV circuitry. Is there a cheap, easy fix?
    Bob
  • 2,337 Answers
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 15, 2008
I have a Vizio E472VL television. When I go to turn it on the logo appears on the screen and the "vizio" icon back light turns on, but nothing else happens. I have tried coax, component, HDMI, etc..
Had the same thing happen to my Vizio TV. It was on warranty, and they replaced the motherboard. It's been fine since then. There appear to be only a very few parts inside. Power supply, motherboard, and display. That's it. Your power supply is good, as is your display. You just need a motherboard.
Jun 09, 2015 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
The TB shut down and will not power back up. Even
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope that works for you as well.
Apr 02, 2010 | Vizio VX37L Television
Please describe your screen black only logo comes on i pulled plug to remove logo cannot use power switch to remove logo problem:
Hi.
All you can do is leaving the TV unplugged for fifteen or twenty minutes, in the attempt to drain power completely and reset it.
Also disconnect all video cables when you restart TV. If TV is still frozen and does not pass POST screen, then the TV eprom must be reflashed, or the mainboard replaced. This must be done by a technician.
Here all parts for your TV:Vizio TV Parts | ShopJimmy.
Try unplugging power and check video connections first.
Regards.
Oct 31, 2009 | Vizio GV42L 42 in. LCD Television
My vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Feb 18, 2009 | Vizio L32 32 in. LCD HDTV
Vizio p42
had the same problem had the main powerboard replaced they were out of stock and had to send mine in and vizio referbed it I was told it was a common problem with this unit
Feb 01, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L37 Television Logo
573 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
