Question about Dryers
The dryer is not heating so the cheapest route would be the thermostat before the heating element. I cannot find the thermostat?
  • Dryers Master
  • 8,220 Answers
The thermostat is located on the blower housing near the filter. It's job is to judge the temp of the air as it passes through to the outside vent. So it is mounted close to where the flexible vent pipe mounts to the dryer.The dryer is not heating - 793e688.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2008
  • 71 Answers
If you will talk to me I will help you through this as cheap as possible . The first Thing is the voltage is it 240 . The Dryer will run but not heat on 120 volts. Let me Know , we will fix it !
Hi, i have a whirlpool duet sport wfw8400tw03. When i run to normal cycle, it stop no error code no light. The washing machine just shut down. I can run it on delicate or sanitary.Is a balance trouble
if u can run it on delicate or fluff cycle with cool air more than likely its ur cycling thermostat or the hi limit thermostat going defective test it with a meter for ohms..
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
HI LIMIT THERMOSTAT DEFECTIVE? SHOULD SHOW OHMS AT ROOM TEMPERATURE
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Whirlpool Kenmore Dryer Won Heat Test Replace Heating Element 279838
Apr 17, 2017 | Whirlpool Washing Machines
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Dec 10, 2016 | Samsung Dryers
I have the Kenmore series 90, model 66901692 black face control panel if that is different and it runs but does not heat up.
Above the thermostat on the heating element box at the top is a resettable thermal fuse. It has a wire coming into it then another one comes out and goes to the thermostat. check that.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 15, 2016 | Kenmore Dryers
No heat in dryer mode
In electric dryers, heat is generated by the heating element. The element is a coil of heating wire enclosed in a metal chamber. Electric current flowing through the coil creates heat and the air being pulled through the chamber absorbs this heat. If the element is defective then it will not heat. It can be tested with a multi-meter for continuity. Unplug the dryer and remove the front or rear panel to locate the element so it can be tested.
The high limit thermostat is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
Dec 02, 2013 | Splendide 2100 Vented Washer-Dryer
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
AEQB6000ES2 dryer wont heat
There are 4 things that can cause this issue: 1. Thermal Fuse (Protects the dryer from overheating and fires) if this is blown, the drum will still turn but you will have no heat. {Cheapest Fix} 2. Heating Element Assembly {Third Cheapest} 3. High Limit Thermostat (if this is stuck OPEN, the dryer will not heat) {Second Cheapest but rare issue} 4. Main Control Board (Check all the other parts first as this is not cheap and there is no way to test it, if the other parts do not fix the issue, replace this. Not a common issue but can be a manufacturer defective item)
Feb 27, 2013 | Kitchen Appliances - Others
Dryer heats up, too hot instantly. Ok on cool down or blower only cycles. All vents clean and clear.
a leading cause of the HOTPOINT dryer to over heat is believe it or not is a broken heat element!!
what happens is since the heat element is broke it falls out of it's holder where it hits a piece of metal causing a unintended circuit through the heater. When it sits on the metal piece whjere it isn't supposed to be anytime power is going to the heater it will heat very hot.That is why it doesnt happen on the cooldown or air fluff cycle since then thier is no power being supplied to the heater. by replacing the heater it will work normally
Gene
Aug 06, 2011 | Hotpoint Dryers
I have a samsung DV337AEG/XAA Electric Dryer which three weeks stopped heating up. We replaced the heating element, along with the thermostat. after that it heated up for 20 minutes then stopped, replaced...
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Mar 25, 2010 | Samsung Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Maytag Atlantis no heat
would go for thermostat usally situated around heater this is the cheapest option if not then it will be the element unplug machine first good luck
Jun 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
