Question about 2000P Radar Detector
I have a k 40 stealth mounted radar unit - it keeps faulting and giving me beeps like every 30 secs
If the beep is one beep every 30 secs then the front radar detector is defective. If it beeps 2x every 30 secs the rear radar detector is defective. If under warrantee you are good. If not, take to any dealer and cost $225 to get it replaced.
Posted on Mar 23, 2009
Where do I mount my radar detector?
The unit comes with a windshield mount - assemble the bracket ( if needed) and secure to a location on the windshield. Make sure its above the wipers and not behind any metal. Once installed, make sure that the radar detector is LEVEL WITH THE ROAD! This may require bending the bracket to level the unit. (Note: remove detector while adjusting the bracket).
Dec 28, 2015 | 14 Band Radar Laser Detector Voice Alert...
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
My K40 unit keeps beeping 2X every 10 seconds or so.. It still goes off when radar is present but it wont stop beeping. any insights would be helpful
You have a K402000 radar system. The double beep is a rear receiver disconnect notification. If you go to the K40 website and access their dealer locator from the dealer section, you can find an authorized dealer to help you with this problem or you can call K40 directly and speak to them...they really are a great company to deal with.
Aug 20, 2011 | Calibre Radar Detector
Got a whistler xrt-695 from individual. unit powers up goes thru all the frequencie alerts and laser alerts, scans menu to tell what is active. Seems to be perfect. x-band is on, K,Ka, Laser, all of it,...
how long have you had it? Have you had a radar detector before this one? Try a factory reset - hold in the power button and the quiet button, while holding in these buttons plug in the power cord. The unit will beep twice indicating that its reset. Remember the unit is not a "Cop" detector its a radar detector so not all police cars have radar in them and if they do they may not have it turned on.
Mar 31, 2011 | XTR695 Radar Detector
Not sensing any radar and not charging the batteries
Make sure that you have the unit set to Combo mode (assuming that your model has a compass feature as you didn't tell us what model you have). You can also perform a factory reset on the unit, With the batteries removed, Press both the power and quiet buttons in, while holding in these butons plug in the power cord. THe unit should beep twice indicating its been reset.
Give this a try. If your still having problems, email info@whistlergroup.com for more info.
Feb 28, 2011 | All Band Laser-radar Detector Radar...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
V1 "J" display??
that is an indication that the unit is "seeing" non radar signals otherwise "Junk"
Dec 05, 2008 | V1 Radar Detector
I have a cobra radar dector esd 737 and i sdoesnt pick up cops tell they are like not even a half a mile ahead of you and tips or ideas how to get it to work better
Detecting of radar or lidar emissions depends on mounting of detector.In My experience it is best to mount it just above windscreen wipers.You must check if your detector is visible from license plate level. This is important for laser detection. For other measuring devices it's only important to be visible.Higher mounting facing downwards will reduce false X and K/Ka signals.It will reduce detecing of true as well, so it is all up to you.You must know that laser detecting only covers your car.It d'ont matter if a cop is 300m or 1800m away.X band has a large emission, and it is easily detected.K/Ka band is a pulse emitting and has a lot narrow detecting point.It is effective at max 800m.In ether case speed can be reduced 20-30 km/h in city, and 30-50 km/h on highway.
Apr 25, 2008 | ESD 7000 Radar Detector
Grill-mounted K-40 continues to "chirp" every 10 seconds...
I too had the same problem and called their customer service. They told me 1 chirp means a front receiver fault, 2 chirps means a rear receiver fault. They suggested I check the wiring and to switch the front receiver with the back receiver to see if the error code would "travel" with it to determine if the receiever was faulty. I did that and the problem went away. I assume I had a connection that loosened up.
Jan 13, 2008 | UN 3000SW Radar Detector
2000P Radar Detector Logo
601 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
