Question about HP L1940 19" LCD Monitor
Dismantel How do I get it open after having removed the stand. No visuel screws . ?
  • 3 Answers
Using a small flat screwdriver, prier the silver frame part from the black frame starting from the top of the monitor them to the sides, and finally the bottom part.
Posted on Mar 16, 2009
How do i dismantel a viking sewing machine 6000 model 6440?
You can remove the rear cover by taking out two screws on the back cover and a screw at the lower rear corner on the side. With this cover removed you can see most of the internal levers and mechanism and be able to access some (not all) components.
Jul 03, 2014 | Husqvarna Viking 1
How to dismantel a pharo shower
Sorry, I am not familiar with that model.
Oct 25, 2011 | Hansgrohe Shower 26101 Pharo Prestige...
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Need to remove speaker how do we dismantel the speaker cabinet for the sp5
you do not need to dismantel . first remove the front grill which is held in place by screws which you are able to see. you need to get a special screwdriver for this, looks like a star screwdriver but i think it has about 6 slots. then only will you will be able to remove the speakers. if you are only removing the diaphragm , all you got to do is remove both handles and unscrew the the driver . then remove the diaphragm from the driver and replace with the new one
Dec 24, 2010 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
How to remove cover to olevia 226-s11 to repair input connector
look all around the bottom of the TV there has to be screws or clamps some around the mother board cover that should help
Aug 26, 2009 | Olevia 227-S11 27 in. LCD TV
Hi...there,
It's open from the front bezel of the screen.. Place a piece of cloth or fiber cloth over the screen and carefully lifted up the bezel... do the same from other angles...
Dec 16, 2008 | HP L1940 19" LCD Monitor
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Replace lower housing
my best advice is for dismanteling the elements of phone give the set to local service station because if by chance we dismantelled important elements the warranty will be void.. so better avoid this... hope i have helped you.
May 07, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Opening the monitor
These are a snap to open.
Put a towel on a flat surface like the dining table.
Remove the 2 screws that hold the stand in and slide the stand out of the hole.
Remove the screw in each of the 2 bottom corners.
Remove the screw in the middle at the bottom (it was under the stand to begin with but some do not have it for some reason.)
Now comes the easy part.
Put a few fingers onto the section the power plug goes into.
Tuck your thumbs into the hole left by the stand.
Push into the power plug section downwards with your fingers at the same time pull upwards with your thumbs. The rear panel should pop up. Gently pop it all around the edges.
Hope that helps =)
Apr 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
How to dismount the monitor
What stand do you have? If it is screwed to the back with 4 or 3 screws, they must be removed first. look along the bottom edge and you will see 3 slots where the two outer cases match up. Put a flat screwdriver into the opening and twist, follow all the way around until you can remove the back half. Cut the tape holding the flat wire and remove the front half to remove the printed board under the front cover. You should now be inside the case. Remove the screws to remove the steal cover to find the printed boards under it. Reinstall is the reverse.
Sep 13, 2007 | LG Flatron L1715S 17" LCD Monitor
HP L1940 19" LCD Monitor Logo
143 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
