Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
Need value fot c661 and c662
Please send me the values of capativity fot c661 and c662 for chasis FSP035 for syncmaster 710n
4 Suggested Answers
  • 36 Answers
SOURCE: syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Posted on Apr 14, 2009
  • 65 Answers
SOURCE: my syncmaster 710n is not working.
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Posted on Feb 16, 2010
budmrtn
  • 11361 Answers
SOURCE: Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 10, 2010
I have been trying to replace a FSP035-1PI01 power board for my VX724 because I figure it would be easier to just buy a new one instead of having to replace the capacitors that are blacked out. I have only...
Hi There,
The seller are right, you should replace using same model number.
For the replacement you no need looking fore the same value, you can replace with higher Voltage (1000 micro farad 16 V can replace with 1000 micro farad 25 V)
Jan 05, 2011 | ViewSonic VX924 19" LCD Monitor
Jun 10, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Feb 24, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Driver of samsung monitor
I will go with Cropp on this one however if you cant find it at that site you may also try driver guide.com
Jun 06, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
NOT OPTIMUM MODE
Solder a 50 ohm precision resistor between pins 5 and 6 of the Novatek NT68F63LG
I had this same problem on 3 Samsung 710N displays and this fixed the problem.
I have read others have also been successful but the value of theresistor was slightly different in some cases. I would start with 50ohms as that seems to be a common value fixing most displays.
Here is the reference URL to the ORIGINAL person that solved the problem.
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
Jan 28, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Is my monitor dead?
I have read others have also been successful but the value of the resistor was slightly different in some cases. I would start with 50 ohms as that seems to be a common value fixing most displays.
Dec 09, 2007 | Samsung SyncMaster 710N 17" LCD Monitor
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Problem LCD screen stays white bright after switch button is OFF ??
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
May 12, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Syncmaster 710N resolution problem
no,
Jan 30, 2007 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
