Question about Teac AG-D8900 Receiver
TEAC DIGITAL HOME RECEIVER AGD 8900 AV
TEAC DIGITAL HOME RECEIVER AGD8900 AV.
Which is the problem???
Hi Dear:I have my Digital Home Receiver AGD8900 Av and its
has the fuse 8 amp,250 volts burnt and I want to know which is the
problem,I did all changes and the problem still there (when put the fuse
and I powerered,its burn again) Please Help Me.
Teac AGD8900 Av Digital Home Theather Receiver
Which is the problem????
Thank you so much in advance
I changed the diodos from power supply.
I thought that help you offered
was free,but I forget that nothing here is free.
Thank you anyway
Posted on Dec 15, 2008
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
Can you hook the vizio sound bar to an av receiver for use with all devices hooked to the receiver thru HDMI?
Why not ? It doesn't know what the source at the other end of that RCA or digital cable is.
Picking the VSB200 as an example.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Vizio-VSB200-Speakers-manual/id/23494ag923/t/2/
The manual shows connections to just about anything.
Not knowing anything about YOUR receiver, you MIGHT be able to draw digital audio out somewhere. Analog audio would be available at any Tape Output. Your receiver
Mar 23, 2011 | Vizio High Definition Sound Bar
Just need to know how to hook up to tv to get sound
If you don't have a cable box or satellite receiver, you will use the "Audio Out" or "Monitor Out" from the TV to any audio input on the receiver. It's just a standard RCA cable or if you have an "Optical input" on the receiver, use that. If you are using a cable box or sat, the audio would come from the cable/sat receiver by standard RCA, Optical, or Digital Coaxial, whichever your AV receiver will support. Hope this helps. If you need further help, post a comment and I can walk you thru it.
Sep 27, 2009 | Zenith ZHD-311 300W Complete Home Theater...
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Yamaha 5.1 receiverhookup to teac equalizer
record output from receiver to linein of eq,and line out from EQ to PLAYBACK of receiver Thank you very much albie 20
Sep 29, 2008 | Teac EQA-120 Home Equalizer
Teac AGD 9100 user guide
Click on your brand name Teac (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line. And dont forget to rate me, on this great site.
Dec 25, 2007 | Teac AG-D9320 Receiver
Setting Up The System
You can find the requested details at: http://www.teac.com.au/file/product_manual_408.pdf
Mar 09, 2006 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver Logo
650 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
