Question about Jabra BT125 Headset
Jabra bt125 won't pair to motorola razor v3
Have done everything properly
I had the same problem and found the user: Splut wrote in another problem the following solution: If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. I tried that to connect my Blackberry phone to my Jabra BT2010 headset and it worked!! I had tried everything prior without success. I hope this works for you. DIVA08
Posted on Dec 22, 2008
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
I lost the instructions. I want to pair my Jabra bt125 with my motorola razr
1. I have the Jabra 125. You can get the manual at if you have a different one.
2. Turn off your phone. Power off. The order of powering on devices is the key.
3. Press and hold your Jabra power button until it's glowing blue (not flashing blue light--but constantly on)
4. Then turn on your phone...and look for wireless devices in your phone menu.
5. Make sure you have bluetooth turned on.
6. the phone will find the Jabra, and then will ask to pair with it. passcode is 0000.
7. That's it.
Again, the key is the order of turning on devices.
Jun 05, 2009 | Jabra BT125 Headset
Can't pair Jabra BT125 with O2mini
check the bluetooth is in visible mode or not
Jan 07, 2009 | Jabra BT125 Headset
Pair with mobile phone
when you activate the Jabra put your mobile to search for the bluetooth device when it finds it then pair code is 0000....then it should be paired
Mar 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
pair up w/ razor
Dec 28, 2007 | Jabra BT125 Headset
Jabra BT125 Headset Logo
170 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
