Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Distorted picture my picture is shrinking and expanding when it shrinks the pic. looks 3d i hkeep on fixing the convergence in the menu but it still goes of conv.
  • Philips Master
  • 3,459 Answers
Common problem and fairly easy to fix. Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Posted on Dec 15, 2008
Picture is distorted
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2011 | Mitsubishi WS-65313 65" Rear Projection...
Picture is distorted, kind of looks like a 3D image without the 3D glasses.
Please do us a favor and rate this solution after reading.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 31, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Upper corner of picture looks like 3D. picture on upper corner looks like it is off vertical with this happening. What do you do to fix this Hitachi 57F500 model?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 21, 2011 | Hitachi 57F500 57" Rear Projection...
The picture shrinked and the colors are one on top of other
  • Screen looks 3D
69189a5.pngCONVERGENCE SOLUTION
Jan 12, 2011 | Hitachi Televison & Video
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more clear and works fine.
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
When tv is turned on the picture is distorted.thought at first that one of the bulbs was bad.took the screen off and all bulbs are lit.the red bulb looks distorted.has the bulbs got to go out to be...
Can you explain distorted in more detail?
Does the screen look 3D?
Can you adjust the convergence for both the blue and red colors - up - down - left - right?
If not the convergence chips and resistors are shot and should be repalced.
If however the screen is shrinking and expanding that is a different problem.  You can get a repair kit from www.TvRepairKits.com for this model.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
