Leaking top-load Maytag - Model # LAT8426AAE
I have a leaking Maytag washer, and I just need to confirm how I get the front off. I don't want to break the front panel attachment assembly....it seems like it might just pull off or something, but don't want to force it. Any help would be appreciated! Thanks,
  • intro_geekin Dec 15, 2008
    Cool, good info, thanks for the response. I believe it's the two push clips, as I did not find screws, which is why I posted to make sure. :) I'll take a look in a few minutes and let you know if I got the front panel off. Thanks again.
  • 71 Answers
Are there 2 screws at the bottom if so remove them and lean out the bottom of the panel . No screws you push 2 clips right under the top on the front with a putty knife or such . Now remove the 2 5./16 screws from front. Please keep up the exchange till we fix it and then rate me fixya
Posted on Dec 15, 2008
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Smoke when running.....smells like rubber....washer is top load.....about 13 years old....model LAT8426AAE...HD 2 speed....9 cycle. Belt shot?
Its possible. This one has two, located underneath. Lean the machine back to check them. Make sure all pulleys turn freely before replacing them
Jul 14, 2011 | Maytag Washing Machines
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Washer does not turn or spins
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Maytag washer overfill
Hole in pressure hose or bad pressure switch. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Dec 01, 2008 | Washing Machines
Maytag Washer leaking from front
If I remember correctly, you need to remove the drum to get at the bolt that you are talking about. There is a rubber washer that provides the seal. The locking collar on the hub is Left hand thread. If you work at it you can get it loose.
Jul 12, 2008 | Maytag MAV2755A Top Load Washer
Washer leaking water
need ot pop off the front cover, insert a screwdriver pop top lean back and remove screws holdng front panel on. try running now see where water coming from (id look to pump assy first)
Feb 29, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
229 people viewed this question
Top Washing Machines Experts
